Is there a way to set the state of a curtain entity based on percentage parameters? I have some MotionBlind curtains that I can not seem to set the open/closed positions on the device and they never close more than 99%.
I use an inverse template to convert this to 1% open however I would like Home assistant to see this as Closed if the value is less than say 5% so that conditional cards and buttons will display a little more accurately (or less accurately depending on how you look at it). Right now they display as open pretty much all the time.
HASS OS Bare Metal V 2024.12.5
My inverse template:
cover:
covers:
rollerblind_inverted:
friendly_name: Curtain Inverse
device_class: curtain
position_template: "{{ 100 - state_attr('cover.rollerblind', 'current_position') | int(default=0) }}"
set_cover_position:
service: cover.set_cover_position
position: "{{ 100 - position }}"
entity_id: cover.rollerblind
open_cover:
service: cover.open_cover
data: {}
close_cover:
service: cover.close_cover
data: {}
stop_cover:
service: cover.stop_cover
data: {}
My YAML and Home Assistant skills in general are poor so please forgive me. The above code was copied and adapted from posts on this forum.
Thanks in advance for any help!
