Set Timer Duration to a variable
I am running Home Assistant version 0.110.5 on a RP4.
I am trying to set a timer based on a sensor crated from my alexa integration. I was able to sort out how to get it in the right format (hh:mm:ss) but it will not let me set the timer with the variable.
"{{(as_timestamp(states('sensor.office_echo_dot_next_timer')) - as_timestamp(now())) | timestamp_custom('%H:%M:%S', 0)}}"
evaluates to
“00:04:07”
But when I try to use it to set duration I get an error that it is not in the right format.  I set up a sensor to store the variable thinking maybe that was causing the problem but I still get the same error.
      time_left_alexa_timer2:
        value_template: >-
          {% if is_state("sensor.office_echo_dot_next_timer", "unavailable") %}
            None
          {% else %}
            {{ (as_timestamp(states('sensor.office_echo_dot_next_timer')) - as_timestamp(now()))  | timestamp_custom("%H:%M:%S", 0)  }}
          {% endif %}
When I use the below it still does not work.
  - data:
      duration: '{{ states("sensor.time_left_alexa_timer2") }}'
    entity_id: timer.alexatimer
    service: timer.start
Any thoughts?
data_template
What petro said and your Template Sensor can’t return none because that’s an invalid value for a timer’s duration.
Try this:
        value_template: >-
          {% set nt = states('sensor.office_echo_dot_next_timer') %}
          {% if not nt in ['unknown', 'unavailable'] %}
            {{ (as_timestamp(nt) - now().timestamp()) | timestamp_custom("%H:%M:%S", False)  }}
          {% else %}
            00:00:00
          {% endif %}
NOTE
The use of False in timestamp_custom means you want UTC time. If you want local time, change it to True or simply remove it because True is the default.
That was my issue. Thank you for the help!
That was one of your issues. Read 123’s post as well.
