In the script below, I’d like to se the variable villkor-sekunder in the beginning of the automation, before the conditions-section. This is because the value of that variable is used in the conditions later in the script.
How is this possible?
I just want my script to run on certain times and by declaring that variable, it will be easy to decide when to run the script. I know i might use a classic time-condition, but that would only clutter the code.
- alias: "Media: Starta radion i köket vid rörelse"
platform: state
entity_id: binary_sensor.multisensor_koksfonstret_sensor
to: 'on'
condition:
- condition: state
entity_id: timer.kitchen_radio_delay
state: 'active'
- condition: state
entity_id: media_player.koket
state: 'off'
- condition: or
conditions:
- condition: template
value_template: "{{ now().weekday() in [ 0,1,2,3,4 ] and villkor-sekunder > 20400 and villkor-sekunder < 27000 }}"
value_template: "{{ now().weekday() == 5 and villkor-sekunder > 28800 and villkor-sekunder < 36000 }}"
value_template: "{{ now().weekday() == 6 and villkor-sekunder > 28800 and villkor-sekunder < 36000 }}"
- service: input_select.select_option
data_template:
entity_id: input_select.chromecast_audio_kitchen
option: >
{% set sekunder = now().hour * 3600 + now().minute* 60 + now().second %}
{% if now().weekday() in [ 0,1,2,3,4 ] and sekunder > 20400 and sekunder < 27000 %}
Sveriges Radio P1
{% elif now().weekday() == 5 and sekunder > 28800 and sekunder < 36000 %}
Sveriges Radio P4 Stockholm
{% elif now().weekday() == 6 and sekunder > 28800 and sekunder < 36000 %}
Sveriges Radio P1
{% endif %}
Move the conditions in to the action block, set the value, run the condition check then preform the final action.
Note that the automation entity itself will now trigger every time the binary sensor switches on and the variable set, but the original action will only be carried out if the conditions are true.
platform: state
to: 'on'
- service: YOUR_VARIABLE_SET_SERVICE_HERE
data: YOUR_VALUE
- condition: state
state: 'active'
- condition: state
state: 'off'
- condition: or
conditions:
data_template:
option: >
Sveriges Radio P1
Sveriges Radio P1
{% endif %}
