Is there a way to adjust the volume out of the speaker? I need to tone it down a bit.
Im using the Max98357
Here is a snippet of my code:
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO25
i2s_bclk_pin: GPIO26
- id: i2s_out
i2s_lrclk_pin: GPIO32
i2s_bclk_pin: GPIO13
microphone:
platform: i2s_audio
adc_type: external
i2s_audio_id: i2s_in
i2s_din_pin: GPIO34
pdm: false
bits_per_sample: 32bit
speaker:
platform: i2s_audio
dac_type: external
i2s_audio_id: i2s_out
i2s_dout_pin: GPIO33
voice_assistant:
microphone: external_microphone
speaker: external_speaker
use_wake_word: true
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 2.5
on_listening:
- lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
- script.execute: control_led
on_stt_vad_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
on_tts_stream_start:
- lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
on_tts_stream_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
on_error:
- if:
condition:
lambda: return !id(init_in_progress);
then:
- lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
else:
- lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
on_client_connected:
- if:
condition:
then:
- voice_assistant.start_continuous
else:
on_client_disconnected:
- lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
switch:
name: Use Wake Word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- if:
condition:
then:
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- if:
condition:
then:
- voice_assistant.stop
globals:
- id: init_in_progress
type: bool
restore_value: no
initial_value: 'true'
- id: voice_assistant_phase
type: int
restore_value: no
initial_value: ${voice_assist_not_ready_phase_id}
script:
- id: control_led
then:
- if:
condition:
then:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
switch(id(voice_assistant_phase)) {
case ${voice_assist_listening_phase_id}:
id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("none").perform();
break;
case ${voice_assist_thinking_phase_id}:
id(led).turn_on().set_rgb(0, 1, 0).set_effect("slow_pulse").perform();
break;
case ${voice_assist_replying_phase_id}:
id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("fast_pulse").perform();
break;
case ${voice_assist_error_phase_id}:
id(led).turn_on().set_rgb(1, 1, 1).set_brightness(.5).set_effect("none").perform();
break;
case ${voice_assist_muted_phase_id}:
id(led).turn_off().perform();
break;
case ${voice_assist_not_ready_phase_id}:
id(led).turn_on().perform();
break;
default:
id(led).turn_on().set_rgb(1, 0, 0).set_brightness(0.2).set_effect("none").perform();
break;
else:
- light.turn_off:
else:
- light.turn_off:
else:
- light.turn_on:
blue: 50%
red: 50%
green: 50%
effect: "fast_pulse"
