I’m not clear how to set a global variable to the state of a component, and then how to use that variable in log statements and in other functions.
I have a Text Component, message_text
, and I want to access the state of this component, put it into a global variable, report the result in a log statement, and be able to use that global variable in other functions.
I’m doing this within a button component:
button:
web_server:
sorting_group_id: group_main_controls
sorting_weight: 30
on_press:
then:
- logger.log: "Updating screen"
- globals.set:
value: !lambda return id(message_text).state;
- logger.log:
format: "Test value of message text: %s"
args: "g_test"
- lvgl.label.update:
text: !lambda |-
std::size_t pos;
std::string str = id(message_text).state;
while ((pos = str.find("\\n")) != std::string::npos)
str.replace(pos, 2, "\n");
return str;
Note that I access that same state later, in the code where I update an LVGL widget (“InfoDisplay”) and I’m not having any trouble there.
With the global variable, “g_test”, I’m just trying to get the string value of the state and report it in a log statement. When I do, I get gibberish as output (see the last line here):
I’ve tried using
c_str()
to get the string info in the lambda, although I didn’t expect it to work. I’ve tried enclosing g_test in double quotes, single quotes, double quotes in single quotes and I still get the gibberish. (Except when I use double quotes in single quotes - then I get “g_test” in the log statement.)
I’m not sure if I’m not getting the proper string value of the state of message_text or if I’m not using the right formatting to make sure the value of g_test prints properly.
Also, I’d like to get this value once and not multiple times (note that I use a different lambda to get it later - I’d rather get it once and then use the global variable to set the value of InfoDisplay. If I can’t be sure I’m getting the right value or how to do it, I can’t count on being able to use the global variable for anything.
So
- What am I doing wrong to get the value and print it in the log statement?
- Will fixing that mean I could, later, do this:
text: "g_text"
which would let set the text in InfoDisplay to the value of the global variable g_text?
