Thanks for the replies. Tried it, doesn’t work, throws an error in the config file. So what I’ve looked at is device configuration and there is a setting:
I can change it to 300 (5 minutes), hit the set configuration parameter button, and restart the network…but it doesn’t take. This is what I get in my logfile:
2020-12-16 17:52:53.685 Info, Node032, Value::Set - COMMAND_CLASS_CONFIGURATION - On/Off Duration - 2 - 1 - 300
2020-12-16 17:52:53.685 Info, Node032, Configuration::Set - Parameter=2, Value=300 Size=2
2020-12-16 17:52:53.685 Detail,
2020-12-16 17:52:53.685 Detail, Node032, Queuing (WakeUp) ConfigurationCmd_Set (Node=32): 0x01, 0x0d, 0x00, 0x13, 0x20, 0x06, 0x70, 0x04, 0x02, 0x02, 0x01, 0x2c, 0x25, 0x6c, 0xd7
2020-12-16 17:52:53.685 Detail, Node032, Queuing (WakeUp) ConfigurationCmd_Get (Node=32): 0x01, 0x0a, 0x00, 0x13, 0x20, 0x03, 0x70, 0x05, 0x02, 0x25, 0x6d, 0xfa
2020-12-16 17:52:56.988 Detail, Node052, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x34, 0x12, 0x56, 0x01, 0x32, 0x02, 0x21, 0x74, 0x00, 0x0f, 0x72, 0x02, 0x00, 0x05, 0x00, 0x0f, 0x53, 0x31, 0x91, 0x17, 0x66
Am I doing something wrong?
