I’m writing a script to send TTS message to my media player, and setting a certain volume. I want to capture and restore the initial volume level but can’t figure out how to set it as a variable during the sequence.
This is the whole thing:
send_tts_to_mediaplayer:
alias: Send TTS message to a mediaplayer
description: Sends TTS message at chosen volume level and restores initial volume upon finishing
fields:
entity_id:
description: Choose target media player entity.
required: true
example: media_player.google_home_mini
selector:
entity:
#device_class: speaker
tts_message:
description: TTS message to send
required: true
selector:
text:
tts_language:
description: Set TTS language, default is English. (use lower caps such as 'nl' or 'de')
selector:
text:
tts_volume_level:
description: Volume level at which to play the TTS message.
required: true
default: 0.5
selector:
number:
min: 0.1
max: 1
step: 0.1
variables:
# temporary
initial_volume_level: 0.2
sequence:
# Turn on media player and wait for idle state
- service: media_player.turn_on
entity_id: "{{ entity_id }}"
- wait_template: "{{ is_state(entity_id, 'idle') }}"
# Check (and store) current volume
- service: notify.persistent_notification
message: "Current volume of {{entity_id}}: {{ state_attr(entity_id, 'volume_level') }}"
# Set TTS volume level, send message and wait for idle state
- service: media_player.volume_set
data_template:
volume_level: "{{ tts_volume_level }}"
- service: tts.google_translate_say
data_template:
message: "{{ tts_message }}"
language: "{{ tts_language }}"
# Restore initial volume level
data_template:
volume_level: "{{ initial_volume_level }}"
I hope someone can help me out with this, or point me in the right direction.
And go easy on me, I’m learning
You can use a scene created on-the-fly to save whatever you need to save
- description: Sends TTS message at chosen volume level and restores initial volume upon finishing
sequence:
- service: scene.create
scene_id: before
snapshot_entities:
- media_player.home_mini_woonkamer
THIS IS WHERE TO DO EVERYTHING YOU WANT
- service: scene.turn_on
entity_id: scene.before
The scene created on the fly will store all the attributes of all the entities that might change during the automation or the script.
It is a very powerful way to rollback to any previous state, in case of failure in the automation for exemple.
Of course, if you don’t want to restore the entity completely, but keep a part of what was done in the script but set back only a few of the attributes to their previous values, saving them in variables as you do is a possibility.
That’s great Olivier, the scene works perfectly. Never thought of using it this way
I actually tried using a variable as per @Rofo 's suggestion at first, but it only works when the media player is already in on or idle state. When it is off, the volume_level state is not available to read. That’s why I’m waiting for idle state as one of the first steps in the sequence.
I think the scene idea is much better, although if the device is off and you can’t get the volume level, I’m not clear how the scene would be able to ?
I’m capturing the scene during the sequence after waiting for the media player to not be in the ‘off’ state. Setting it as a variable happens before the sequence starts and the device is possibly still off.
Waiting for it to not be in the ‘off’ state as opposed to it being in the ‘idle’ state, as I did before, means it will also work when the device is paused or playing media at the time.
sequence:
# Turn on media player and wait until it is not in 'off' state
- wait_template: "{{ is_state(entity_id, 'off') == false }}"
# Create scene from snapshot to capture initial volume level
scene_id: mediaplayer_before
snapshot_entities:
- "{{ entity_id }}"
[ DO STUFF ]
# Turn on captured scene, restoring initial volume level and activity/stream
entity_id: scene.mediaplayer_before
Added benefit of using the scene solution is that it also restores media that was playing when the message came through.
Great tip, though I still have the same problem I had with the old method : my homepod sporadically play music after execution even though they were not playing before
