Hey, I’m pretty new to Home Assistant and I would like to activate Do not disturb mode on my Android phone (where I installed the companion app). Reading Do not disturb state is definitively possible but can it be changed from HA?
I would like to add it to my Good night/Good morning routine. I tried doing this directly with Alexa but I’m afraid Alexa only can change Echo devices.
Definitely doable with Tasker. It would be in the Audio action category when creating the Task. I use Tasker to turn on and off my Sleep Tracker (Sleep with Android) with my Goodnight Routine every night. Could easily add DND to that Task if I wanted.
I was able to get this to work on my Pixel 5 using the Home Assistant application and following the process defined at Notification Commands | Home Assistant Companion Docs - worked great. Now when I am at the church building my phone goes into “priority_only” mode - so cool!
HA rocks!
CoyoteRay
PS: Tasker is also very nice and I will recommend it to others.
Hello! In case anyone was interested, I also followed the document that @CoyoteRay linked to here and it worked perfectly, running Android 13. My use case was a bit different. I wanted to force my phone out of DND mode when a flood sensor detected an issue (say, in the middle of the night when you least expect it!). In that case, you send a separate message first to your phone, and set your command_dnd data to “off” and then send the notification you want to see on your phone after that.
Worked flawlessly once I sent the initial DND push command to allow DND access to my phone via the companion app. Thanks again
I just added this Do Not Disturb to one of my automations at night. What would be awesome (but not yet supported) would be to also disable the ‘tilt to wake’ on Wear OS watches since I currently turn on ‘theatre mode’ during the night whilst using the watch for sleep monitoring.
My Pixel 9 has DND Modes, example: “Bedtime”, “Driving”, as well as Custom etc. Is there any way to activate one of those through this method?
If not, maybe a way to change the DND settings by the “command_activity” method where it sends an intent? Like for example, change the “Who can interrupt” from “none” to “starred contacts.”
I need to set my phone to ringer_mode normal in order to get the alarm_steam to work on Android 15 when DND is on. But that also disables DND (and yes alarms should go through with DND on, but somehow don’t on Android 15).
This means when this alarm is triggered at night, it disables DND and I would like my to have my DND mode reactivated at the end of my automation so that I am not woken up by messages later in the night. But the documentation doesn’t say anything about how you can select a certain DND mode profile to be enabled. It only says you can enable it as for example priority only, but not the profile you have created.
