How do I set autoheal: false in version 0.89?
I don’t have the zwave: entry in configuration.yaml anymore.
I tried this in core.config_entries:
“data”: {
“network_key”: “xxxx”,
“usb_path”: “xxxx”,
“autoheal”: false
But it still performs an autoheal at midnight.
You mar want to look in toe config/.storage folder. (yes, the name starts with a ‘.’ making is hidden sometimes)
That is where the “magic” is stored.
That’s what I’m doing. The core.config_entries file is in that folder.
I assume you restarted HA after any changes.
You could delete the zwave binding & then set it up in the configuration.yaml.
I initially started in the configuration.yaml, deleted it & then went to the Lovelace config.
You still use configuration.yaml for settings besides the network_key and usb_path. See the note in the configuration docs.
This is my current config:
zwave:
autoheal: false
device_config: !include zwave_device_config.yaml
You can, but not if it is also defined through lovelace. HA only permits 1 zwave configuration.
Not sure what you mean, but as I mentioned, only the usb_path
and network_key
are configured by the integration. Everything else is configured in configuration.yaml
I initially had my zwave defined in configuration.yaml and it would not let me configure through lovelace, giving an error.
I them deleted the configuration.yaml entries to use the lovelace config. I do not think you can mix them like that,
Thanks @anon34565116 and@freshcoast!
I removed the autoheal from core.config-entries and added
zwave:
autoheal: false
to configuration.yaml yesterday.
And there was no trace of any healing last midnight.
Now I’m curious as to how my system will behave after a few days.
