Thankyou for replying once again!
This might be more than what you are asking but I am posting everything to make sure I am not omitting any context.
This is my wrapper script for lifxlan:
cat /usr/local/bin/lifx_control.py
#!/usr/bin/env python3
from lifxlan import *
import sys
import json
import getopt
from time import sleep
def usage():
print("\nUsage\n")
print('Usage control specific device: '+sys.argv[0]+' -i <ip> -m <mac> [options]')
print('Usage get all devices: '+sys.argv[0]+' -g -j')
def getAllDevices(mode):
lifx = LifxLAN()
# get devices
devices = lifx.get_lights()
#print(json.dumps(d, default=lambda o: o.__dict__))
if mode == 'json':
jsonObj = {}
for d in devices:
jsonObj[d.mac_addr] = {
'mac': d.mac_addr,
'ip': d.ip_addr,
'label': d.get_label(),
'location': d.get_location_label(),
'group': d.get_group_label(),
'product': d.get_product(),
'color': d.get_color(),
'power': d.get_power()
print(json.dumps(jsonObj))
else:
for d in devices:
print("{} ({} - {}) HSBK: {}".format(d.get_label(), d.ip_addr, d.mac_addr, d.get_color()))
def main():
try:
opts, args = getopt.getopt(sys.argv[1:], "hr:i:m:t:c:s:b:k:d:vgj", ["help", "group=", "ip=", "mac=", "toggle=", "color=", "saturation=","brightness=","kelvin=","duration=","json"])
except getopt.GetoptError as err:
# print help information and exit:
print(str(err)) # will print something like "option -a not recognized"
usage()
sys.exit(2)
mode = None
ip = None
group = None
mac = None
toggle = None
saturation = None
color = None
brightness = None
kelvin = None
duration = 1
verbose = False
for o, a in opts:
if o == "-v":
verbose = True
elif o in ("-j", "--json"):
mode = 'json'
getAllDevices(mode)
sys.exit()
elif o in ("-g"):
getAllDevices(mode)
sys.exit()
elif o in ("-h", "--help"):
usage()
sys.exit()
elif o in ("-r", "--group"):
group = a
elif o in ("-i", "--ip"):
ip = a
elif o in ("-m", "--mac"):
mac = a
elif o in ("-t", "--toggle"):
toggle = a
elif o in ("-s", "--saturation"):
saturation = a
elif o in ("-c", "--color"):
color = a
elif o in ("-b", "--brightness"):
brightness = a
elif o in ("-k", "--kelvin"):
kelvin = a
elif o in ("-d", "--duration"):
duration = a
else:
assert False, "unhandled option"
if verbose:
print("IP: " + ip)
print("MAC: " + mac)
print("GROUP: " + group)
if group is not None:
print("Group action")
#create group
lifx = LifxLAN()
bulb = lifx.get_devices_by_group(group)
else:
# create device
bulb = Light(mac, ip)
#print(bulb.__dict__)
if toggle == 'blink':
print('Blinking device')
toggle_device_power(bulb)
sys.exit(0)
if toggle == 'off':
print('Turning device off')
bulb.set_power('off', duration)
sys.exit(0)
if not (color and saturation and brightness and kelvin):
if color is not None:
bulb.set_hue(color, duration)
if saturation is not None:
bulb.set_saturation(saturation, duration)
if brightness is not None:
bulb.set_brightness(brightness, duration)
if kelvin is not None:
bulb.set_colortemp(kelvin, duration)
else:
bulb.set_color([color, saturation, brightness, kelvin], duration)
if toggle is not None:
bulb.set_power(toggle, duration)
sys.exit(0)
#bulb.get_power()
print(bulb.get_power())
print("Selected {}".format(bulb.get_label()))
# get original state
original_power = bulb.get_power()
original_color = bulb.get_color()
bulb.set_power("on")
sleep(0.2) # to look pretty
print("Toggling power...")
toggle_device_power(bulb, 0.2)
print("Toggling color...")
toggle_light_color(bulb, 0.2)
# restore original color
# color can be restored after the power is turned off as well
print("Restoring original color and power...")
bulb.set_color(original_color)
sleep(1) # to look pretty.
# restore original power
bulb.set_power(original_power)
def toggle_device_power(device, interval=0.5, num_cycles=3): #TEST
#original_power_state = device.get_power()
device.set_power("off")
rapid = True if interval < 1 else False
for i in range(num_cycles):
device.set_power("on", rapid)
sleep(interval)
device.set_power("off", rapid)
sleep(interval)
#device.set_power(original_power_state)
device.set_power("on")
def toggle_light_color(light, interval=0.5, num_cycles=3):
original_color = light.get_color()
light.set_color(BLUE, rapid=rapid)
sleep(interval)
light.set_color(GREEN, rapid=rapid)
sleep(interval)
light.set_color(original_color)
if __name__=="__main__":
main()
If I invoke this script like this I will get the warm violet I am after:
/usr/local/bin/lifx_control.py -m d0:73:d5:xx:xx:x -i 192.168.xx.xx -c 48620 -s 655 -k 2750
Attached you find photos showing the results of invoking lifxlan-command vs the lifx.paint_theme with the values you very kindly calculated for me.
