Setting default light settings on start-up issues [solved]
Hi All,
Thanks to some help in discord, I was able to solve this… wanted to leave the answer here for others.
The issue I had was, i couldn’t set the RGB, brightness and color_temp in one command. As a result, I split the work across to service calls. This introduces a few seconds of lag - which is fine as I just wanted a quick way to make sure my system turned on with my preferred settings (or could easily be put back if someone was playing around).
https://hastebin.com/wowoperage.hs
- alias: 'set lights to default'
    platform: homeassistant
    event: start
    - service: light.turn_on
      entity_id:
        - light.dining
        - light.lounge
        - light.hallway
        brightness_pct: 100
        #color_temp: 420
        rgb_color: [255, 255, 255]
      entity_id: light.bathroom
        brightness_pct: 100
        #color_temp: 155
      entity_id:
        - light.dining
        - light.lounge
        - light.hallway
        color_temp: 420
    - service: light.turn_off
      entity_id:
        - light.dining
        - light.lounge
        - light.hallway
Hope this helps others
