Setting Fixed IP Address
I am trying to configure a LocalByes ESP8266 Plug to use a fixed IP address and not DHCP, but can’t get the IP Address section to work.
If I remove the manual_ip section it installs fine, if I include it, it fails with
INFO Successfully compiled program.
INFO Connecting to 192.168.8.3
ERROR Connecting to 192.168.8.3:8266 failed: [Errno 113] No route to host
wifi:
  fast_connect: True
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.8.3
    gateway: 192.168.8.1
    subnet: 255.255.255.0
Any know what I am doing wrong ?
See here:
Use:
  use_address: 192.168.8.[CURRENT DHCP ADDRESS]
to flash the new code. Then once the device is up and running at .3, remove that line and reflash.
Another option is to enable a web server in ESPHOME, and upload the compiled bin file through that.
That did it :smile:
