Setting HUE min_& max_mireds with input from blueprint
I have replaced most of my spot with HUE white ambiance spots, and I made some blueprints to have them behaving the way I would like them to while dimming etc.
One thing missing is the possibility to set the min and max color_temp. I would like this to be done using inputs in blueprints. Is this possible so I can set the min and max values differently for each group dimming automation based on a blueprint?
Thanks.
yes.
If you can do in in an automation or script, you can do it with an automation or script blueprint.
Do it first, then convert it to a blueprint is the easiest way.
Thanks for the reply. I looked and tried several ways but non seem to work.
Could you give me a pointer on how to code this? Thanks
