Setting my router for DuckDNS access
I am having an issue with setting forwarding ports on my providers router that I get from them.
Model router: 854G-2
Here is the pic: router configuration port forwarding
I setup duckdns, but as I expected I don’t have acces from duckdns url which I was added to my hassio configuration file.
Is this correct in my router settings? I mean, I set range exactrly for port 443 (ssl) and outbound port is 8123?
I can access from my local url: http://hassio.local:8123
You now need to use https not http. You will get a certificate error unless you use your duckdns.org URL, even locally.
I know, But this is not the main issue. The main issue is “visibility” of my ports in external WAN.
