I’m trying to dynamically set a script variable based on choose conditions, I’ve tried it in two different ways but neither will actually set the script variable. Anyone any pointers? I really don’t want to copy and past the same bit of logic all over my choose branches. The script is a condensed version of the real one, it might not even work but hopefully does demonstrate what I’m trying to achieve:
You’re running into a variable scope issue. Both of those chooses pull from the variable defined above and do not impact eachother. Put your condition in the variable in your main sequence, not a separate choose.
And thanks for the answer, I suspected it was a scoping issue but just to be clear, I seperated the two scripts. Because if I understand you correctly method 2 (below) should work?
