Setting the time Problem
You’re welcome!
Before you go, please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which indicates to others that the topic has been solved. This helps other users find answers to similar questions.
Ok, This was the solution for my first problem. But if I wanted to make a sensor from this code how do I do this or is that not possible? Thanks for thinking along.
Which code exactly? Your automation contains a repeat and you can’t use that in a Template Sensor.
If it’s just a small part of the code, like the condition made with an if-then-else, a Trigger-based Template Sensor supports a condition option.
If you need to include code like repeat then that can go in the action section of a Trigger-based Template Sensor (where you can define variables).
All this to say that you should explore the capabilities of a Trigger-based Template Sensor and see if it meets your needs.
  - if:
      - condition: template
        value_template: |
          {{states('sensor.max_temp_gevraagd') <=
            states('input_number.verwarming_normaal')}}
    then:
      - if:
          - condition: time
            after: input_datetime.living_thermostaat_tijd_dag
            before: input_datetime.living_thermostaat_tijd_nacht
        then:
          - variables:
              Temp: |
                {{ states('input_number.living_thermostaat_temp_dag') }}
        else:
          - variables:
              Temp: |
                {{ states('input_number.living_thermostaat_temp_nacht') }}
    else:
      - if:
            value_template: |
              {{state_attr('climate.thuis', 'current_temperature')|float + 0.5 >
                state_attr('climate.thuis', 'temperature')|float}}
        then:
          - variables:
              Temp: >
                {{ state_attr('climate.thuis', 'current_temperature')|float +
                2}}
        else:
          - if:
              - condition: time
            then:
              - variables:
                  Temp: |
            else:
              - variables:
                  Temp: |
Thanks for your response.
Above you will find the piece of code that is the issue.
