Hi !
My appartement has an underfloor heating, currently managed with analog unconnected thermostats.
I’m looking to manage temperature through home-assistant, also I did some extensive research and came up with the following. Do you believe this should work properly ? Any recommandation or things to pay attentation to ?
Each loop already has the following device Danfoss - ABN‑FBH 230 NC 230v (single phase actuator, 1W)
I would add the following switch Shelly Pro 4PM (twice to cover the 8 loops)
Put in each room a temperature sensor such as Aqara one
Finally create a generic thermostat with each pair “Shelly switch / Aqara sensor” /integrations/generic_thermostat/
