You assumption is correct denver. You would double the requests when using both integrations.
If you want to keep the weather integration (and can live with the fact that not all data of the sensor integration is available when using the weather integration) you can use the template sensor to extract the required data.
sensors:
dark_sky_temperature:
friendly_name: Temperature
entity_id:
- weather.dark_sky
unit_of_measurement: "°C"
device_class: temperature
value_template: "{{ states.weather.dark_sky.attributes.temperature }}"
Thank you Florian, this all came about whilst dabbling with dashboards. I had been using the weather platform with no problem but whilst playing around with dashboards it seems to require the weather sensor. Unless there’s away around that.
Lovelace is all I need so I can’t say if there is a way around that. But the usage of the above mentioned template sensor allows to create most of the dark sky sensor information without losing the weather integration. Just give it a try, maybe it does the job for dashboards too
Hi Guys - also having some trouble setting up Dark Sky with Home Assistant… Followed the instructions here and signed up for darksky API. I don’t see the information show up on the HA dashboard. Is there something else I need to configure? Thanks!
