It looks like google_assistant component is not activated at startup time. But no configuration or runtime error at any time. IFTTT and dialogflow API calls running without any issue. It is strange that there is no error in log file when 404 error returned.
Ohhh, it was my stuping mistake. The system did not apply my config change.
I have noticed that configuration.yaml was not changed after one reboot of RPi.
Now /api/google_assistant is served.
Yes, If I understand this correctly it would allow custom Dialogflow invocations instead of âtalk to <appname>â. That would be really awesome!
Has anyone gotten both Google Assistant and Dialogflow working at the same time?
edit: canât seem to get dialogflow working with multiple invocations. Only have âtalk toâ workingâŚ
I have this same issue, everything works when i set my phone to English-US, but when I have it in Italian I canât find the Home Control in the Google Assistant settings. Also, when using the simulator @ https://console.actions.google.com/, after i switch language to italian i get the âApp cannot be tested because it does not yet support âit-ITâ as a localeâ message.
You have Google Assistant in Italian language?
I still donât have it
Yes it has been released a few days ago
I have it in English, if I change phone language to Italian all menus are greyed out.
Do you have a Google Home? Did you try to change language to Italian?
Google Home is not yet available in italian afaik
Iâve got GA setup and working but I wonder how to add more devices. Initially I just exposed lights and switches, but when I add other domains they do not become visable in the google home app after (re)linking. I keep getting the same devices as before, no scripts etc. while I have added them to the exposed domains. (running hassbian 0.58)
Is there the refresh option?
Not sure where it should be. If in the home app, there is only an option to unlink not to refresh. I aslo did âtest draftâ in the google console to reinitialize the app(?.. I think)
Just noticed I do get a lot of messages in the HA log:
[homeassistant.components.google_assistant.smart_home] aliases must be a list
Problem solved⌠forgot to reboot HA
And you have the refresh?
I am on hassio, no update available
Not in the app, but maybe refresh is an automatic mechanism?
A couple of notes on 10165.
For refresh to work, you will have to unlink and relink your test app at least once after setting up config changes with the new release.
The refresh is added as a new service to the GA component called request_sync. You can either trigger it in HA through the âservicesâ menu or use it in an automation as you would any other service.
I didnât found this service on HA 0.58, even after unlink the test app
Did you also add the api_key
as detailed in step 9.
If you donât then google_assistant.request_sync
isnât available.
Thanks, i forgotten to do it.
Now itâs fine
Thanks, seems to work perfectly!
I can see the new service, but when trying to update the test app it didnât update at all, but now after unlink the app it can be link again, what can i do now? I donât have any device any more, tried to restart HA but no luck
