Setting up Influxdb on QNAP (Docker)
Did anyone do this?
I’m having problems with the initial setup/install here.
I can install the separate containers fine, or at least they finish and start running.
However…how do I get to the config files/parts?
Should I do anything when intstalling the containers? Moun paths/volumes etc?
When I try to check if Kapacitor is running with this command:
kapacitor list tasks
i get this response back
Get http://localhost:9092/kapacitor/v1/tasks?dot-view=attributes&fields=type&fields=status&fields=executing&fields=dbrps&limit=100&offset=0&pattern=&replay-id=&script-format=formatted: dial tcp [::1]:9092: getsockopt: connection refused
