Setup failed for timer: Component failed to initialize
When I changing in configuration.yaml
form
timer: !include timer.yaml
to
timer: !include_dir_merge_list timers
I am getting an error in the logfile:
Setup failed for timer: Component failed to initialize.
I enabled debug level of logging, but it is no additional information in log file. Only:
2019-04-01 21:36:33 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up: - timer Please check your config., notification_id=invalid_config>
What am I doing wrong?
I haven’t tried this with timer exactly, but my guess is you should be using this instead:
timer: !include_dir_merge_named timers
See this doc section for more details.
