Setup intensity input for EV charger with variable
Hello
I’m trying to setup the intensity of my EV charger with a variable.
Here is the working code with a fixed number:
device_id: c7f78efbcb8696a1e33fe8bf1f7ada75
domain: number
entity_id: number.ev_charger_1_set_charge_current
type: set_value
value: 10
Here is what I tried, but does not work:
domain: number
type: set_value
value: "{{ states('input_number.chargeur_intensity') | float }}"
I m getting the error :
Message malformed: expected float for dictionary value @ data['value']
Thank you inadvance for your help !
Device actions do not support templates. Use the number.set_value action.
action: number.set_value
  value: "{{ states('input_number.chargeur_intensity') }}"
Some light reading for you: Why and how to avoid device_ids in automations and scripts
Thank you very much, that’s working
and thanks for the reading :slight_smile:
