Setup mqtt for covers esphome
Is there a chance someone is able to help me out setting up mqtt for my esphome covers.
the code so far:
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "abdaacbbcd904e626f97dc760950e0d9"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Screen-3 Fallback Hotspot"
    password: "KvvRTfhxCvVS"
captive_portal:
#Webportal
web_server:
  port: 80
switch:
#Restart
  - platform: restart
    name: "Somfy Screen-3 restart"
#Somfy Screen 3
  - platform: gpio
    pin:
      number: D1
      mode: output
      inverted: true
    name: "Somfy 3 remote Up"
    on_turn_on:
      - delay: 500ms
      - switch.turn_off: up
  - platform: gpio
    pin:
      number: D2
      mode: output
      inverted: true
    name: "Somfy 3 remote Stop"
    on_turn_on:
      - delay: 500ms
      - switch.turn_off: stop
  - platform: gpio
    pin:
      number: D3
      mode: output
      inverted: true
    name: "Somfy 3 remote Down"
    on_turn_on:
      - delay: 500ms
      - switch.turn_off: down
cover:
    device_class: shutter
    assumed_state: true
    optimistic: true
    open_action:
      - switch.turn_on: up
    stop_action:
      - switch.turn_on: stop
    close_action:
      - switch.turn_on: down
Thanks in advance!
Simply
mqtt:
    broker: mqtt.lan
    username: !secret mqtt_user
    password: !secret mqtt_pwd
    discovery_prefix: "ha_stream"
Or do you mean setting MQTT altogether?
yes please. the goal is to control my covers via MQTT instead of the ESPHome API.
