Setup SLZB06M with OTBR on Home Assistant Green
I’m trying to setup the SLZB06M as a Thread router. It does not show up in my device list in the OTBR configuration.
  • it’s connected via Ethernet
  • I’m using the HA Green
  • I have no issue when set up with ZigBee
Is there any way to make it work?
Thank you!
If it is running a Zigbee-only firmware, then you need to reflash it to a Thread-only firmware or a MultiPAN firmware.
MultiPAN firmware is something Sonoff provide and support.
