When I first plugged in to POE and configured to use zigbee only and ethernet, HA discovered device with both ZHA and SMLIGHT integration. Is the SMLIGHT integration a replacement for ZHA or just a way to monitor the device? Do I still need ZHA if I install SMLIGHT?
They are not interchangeable. The SMLIGHT integration is only for monitoring the coordinator, not for creating a zigbee network. You’ll still need to use ZHA (or Zigbee2MQTT).
thanks for explaining!
