I’ve installed Hassio on my pi 4 yesterday and the first thing I want to do is setup device tracking via iCloud. I adde the following with correct values to the configuration.yaml file:
There’s a code button there too. Or use backticks ``
Want to know if it actually added any devices?
Go to the developer page > states and look for device_tracker.yourphonesname
If you have taken control of the GUI, then you have to manually add the device to the frontend. If the device doesn’t show up, you should consult your logs for details.
Thanks to both of you. I have my phone showing up on the map and logs my movement from zone to zone. But it only seems to work when the iOS HA app is running.
What I’m after is device tracking without an app being open (I want to know when the daughter leaves school and gets home safely).
Any advice on how to go about this? I installed OutTracks (?) on my iPhone but couldn’t find the integration in the HA add on store.
