Several monochromatic ledc lights
Good day,
I’m not very experienced in esp home and I don’t know how to deal with this problem anymore.
I need several led lights that will shine with different effects.
When I have entered in esp32 one monochromatic ledc light with an effect, it works correctly.
As soon as I add the second light the first one stops working and the second one works.
I’ve tried entering different channels for both lights to no avail.
Anyone have an idea how to fix this?
Share your attempted config.
output:
  - platform: ledc
    pin: GPIO17
    inverted: True
    channel: 12
  - platform: ledc
    pin: GPIO21
    inverted: True
    channel: 0
# stavová led tlačítka start
light:
  - platform: monochromatic
    output: led_stav
    output: led_red
    effects:
      - pulse:
          transition_length: 150ms
          update_interval: 150ms
      - pulse:
          transition_length: 1s
          update_interval: 2s
      - pulse:
          transition_length: 100ms
          update_interval: 500ms
Thanks. Config looks ok.
The first one stops working altogether or just has no effects?
If it stops working altogether, double check your wiring and if all good open an issue here: Issues · esphome/issues · GitHub
It’s not wiring, I’m testing it on the circuit board. Just delete (disable) the lines for the second light in the config and the first light will start flashing again, as it should.
Right so even though you did not actually answer my question I can guess you need to do this:
light:
    output: led_stav
    effects:
      - pulse:
      - pulse:
          update_interval: 2s
      - pulse:
    output: led_red
    effects:
      - pulse:
      - pulse:
          update_interval: 2s
      - pulse:
The effects list is not global. It needs to be defined for each light.
tom_I, thank you for your advice. I didn’t know that, now everything works correctly.
