Hi All,
My scenario is 2 separate Home Assistant servers on totally separate private networks, but they are both joined to the same tailscale network. I can ping bidirectionally between the Primary HA & Secondary HA over the Tailscale network:
- Primary HA - Synology Home Assistant Docker Container (so no add-on store)
- Secondary HA - Raspberry Pi 4 running HASS
Anyone have a working configuration where you shared a sensor from Primary HA to Secondary HA using the Tailscale mesh?
I’ve attempted MQTT by running a mosquito broker on Primary, but it just isnt working. I’m thinking there has to be a more direct way, since both are technically on the same network (from VPN perspective)…
