It’s works on my Android phone and tablet. Thanks
I got this error :
Uncaught TypeError: Class constructor HaPanelFloorplan cannot be invoked without ‘new’
Anybody who knows what to do ?
Running 070.1
As seen in an example in this topic I want to show temperature. This works, But I want to add a big “C” but this is not shown in my floorplan . What did I do wrong ?
my code:
floorplan.css
https://paste.ofcode.org/aHef42YL3AsdNWwPe2aGTd
floorplan.yaml:
- name: Fans
entities:
- fan.server_room_fan
states:
- state: 'on'
class: 'fan-on'
- state: 'off'
class: 'fan-off'
state_transitions:
- name: On to off
from_state: 'on'
to_state: 'off'
duration: 2
in my svg add:
fan.server_room_fan
not work for me
Put the big C in it’s own seperate object.
do you mean in a seperate toplayer ?
You should only give your two zeros the entity id’s name. The rest should not be linked to an entity_id in your svg document.
A separate one from your zeros.
my c has this ID:flowRoot912-8 , and my 2 zeros : sensor.temperature_158d0002376460.
They are in seperature layers. But the C is not seen …
Try moving it to the top layer then.
it is already …
Could be a missing font, or something similar as well.
Ok, then it is something wrong with your grouping. Probably is your background above your C. You need to be sure that your C is above your background in your group, else move your C directly under your layer, so you are sure it is over the background. And be sure that your background is below your C.
changed font, nothing happened, layer with c is on top … nothing happened
Tried this instead?
@-webkit-keyframes rotation {
from {
-webkit-transform: rotate(0deg);
to {
-webkit-transform: rotate(359deg);
Probably won’t work, but worth a shot. I suppose the fan component reports state on or off? (not a number in percent or something)?
What happens if you color your C to red and move it to the white space (where it cannot be be hidden under a layer)?
