Share your Lovelace Projects (specifically ios/android versions)
This is the current state of my constantly changing lovelace setup, viewed from my phone.
Home Screen:
Some other Examples:
how did u managed to get those titles (like sensoren)?
what theme are you using?
since i guess you using the button-card: mind sharing your template?
You are correct the titles are button cards, here is the code:
- type: "custom:button-card"
  name: QUICK LINKS UND INFOS
  color_type: label-card
  color: 'rgba(0, 0, 0, 0)'
  styles:
    card:
      - height: 30px
      - padding: 0%
    name:
      - font-size: 20px
      - font-family: Oswald
      - color: "#ffffff"
      - justify-self: start
      - padding-bottom: 3px
The theme i’m using is an edited version of Clear Theme Dark
It could be done much easier with markdown cards though. That is how I use it in my current setup, see screenshot:
The button cards don’t add to much bulk to the config when using button card templates, but I might consider changing over to markdown cards. Thanks for the tip :+1:t2:
Using markdown would be my preference solely because it is a core card.
Config would look something like this:
type: markdown
style: |
  ha-card {
    background: transparant;
    font-family: yourfont;
    font-size: 15px;
content: Livingroom
You can simply template this as well. Saves you a lot of code I think and it will persist even if button card will stop working (for whatever reason, which has happened in the past where button-card got broken for months until @romrider picked it up).
You do need card-mod though!
Edit: though you are right, your code isn’t as excessive, but still I think core cards should be better for this as it is… well it is core :rofl::joy:.
When used in combination with lovelace gen your actual config will be 2 lines for each “headline”. As opposed to decluttering-card which will need 3 lines. (Sounds a bit picky I know srry haha)
thats also a nice idea.
however i have a border around the card now, guess of the theme?!
do you know if there is a way to remove that?
Using markdown? Try this
type: markdown
style: |
  ha-card {
    font-size: 15px;
    box-shadow: none;
content: Livingroom
Should be enough, if it isn’t you could add border-radius: none;
Though I believe box shadow should be enough.
I’m already using card-mod and lovelace gen so I tried your suggestion. You are right, using button card for titles is somewhat overcomplicating things.
- !include
  - ../includes/titles.yaml
  - title: QUICK LINKS & INFOS
titles.yaml
# lovelace_gen
type: markdown
style: |
  ha-card {
    font-size: 20px;
    font-family: Oswald;
    height: 30px;
    background: none;
    margin-top: -0.9em;
    margin-left: -10px;
    margin-bottom: 0.9em;
content: {{ title }}
Yes exactly like this!
It’s amazing how it is possible to miss new and better way to do something simply because doing it the old way works!
However….
Is there a way to template the style elements? I can’t get it to work.
e.g.
  default:
    - font-size: 24px
    - background: none
    - box-shadow: none
  card:
    type: markdown
    content: '[[label]]'
    style: |
      ha-card {
        background: '[[ background ]]';
        font-size: '[[ font-size ]]';
        box-shadow: '[[ box-shadow ]]';
Hm, I wonder what the config above card is?
However I don’t think templating like that will work. Looking at the config I assume you use decluttering-card? I believe it is possible with lovelace_gen though.
You can however use jinja inside that area. I myself use it with input_selects and an automation. For example, I can change the entire theme’s border radius and box shadow by flipping a switch (input_select). You can find my repo at https://github.com/jimz011/homeassistant for some examples (warning! There is a lot on the repo!)
Anyways what you are trying to do is (to my knowledge) not possible with decluttering-card. Try it with lovelace_gen maybe like the above example by @aFFekopp.
hi, trying to understand what you’re doing here… how is this a card config?
could you please show what is above the first include? thanks!
It’s using :small_blue_diamond: Lovelace_gen - Add abilities to ui_lovelace.yaml. The include is referencing the code in titles.yaml that I have also posted.
Take a look at the Lovelace Gen documentation: Passing arguments to included files
o right, I see.
I dont use lovelace_gen thats why I was surprised by the code you posted. Just so I understand correctly, this is in fact a template using the title QUICK LINKS & INFOS as variable? Which can be done also using a decluttering template I think,
card:
  type: markdown
  style: |
    ha-card {
      font-size: 20px;
      height: 30px;
      background: none;
      margin-top: -0.9em;
      margin-left: -10px;
  content: '[[title]]'
in this case?
Cool, thanks for pointing me to Lovelace_gen…
Correct it’s similar to decluttering templates
My main screen from phone
Hello!
I’m really inspired by all the ideas that’s been shared within this thread :dizzy: I recently decided to redo my UI and went for a cleaner look. Here is how it looks on our wall mounted tablet:
Different devices are divided into different views
Thanks again to everyone for sharing all the awesome UIs :heart:
I’ve done something simple (mobile only) like this:
Nice @postlund. Simple can be nice you know :stuck_out_tongue:
Any eta on the atv component btw?
Merry Christmas
