yes you are right after a few tries i managed to make the remote transmitter only activate rmt when i transmit and disable it directly afterward and also take care of the input output change. if anyone else needs this these are the changes i made, copied remote transmitter folder and used it as a external component with these changes in remote_transmitter_esp32.cpp
for some reason the first time you transmit nothing happens but after that its working just fine…
anyway thanks for the tip on where to start.
#include "remote_transmitter.h"
#include "esphome/core/log.h"
#include "esphome/core/application.h"
#ifdef USE_ESP32
#include <driver/gpio.h>
namespace esphome {
namespace remote_transmitter {
static const char *const TAG = "remote_transmitter";
void RemoteTransmitterComponent::setup() {
this->inverted_ = this->pin_->is_inverted();
//this->configure_rmt_(); //------------------------------removed
void RemoteTransmitterComponent::dump_config() {
ESP_LOGCONFIG(TAG, "Remote Transmitter:");
ESP_LOGCONFIG(TAG,
" Clock resolution: %" PRIu32 " hz\n"
" RMT symbols: %" PRIu32,
this->clock_resolution_, this->rmt_symbols_);
LOG_PIN(" Pin: ", this->pin_);
if (this->current_carrier_frequency_ != 0 && this->carrier_duty_percent_ != 100) {
ESP_LOGCONFIG(TAG, " Carrier Duty: %u%%", this->carrier_duty_percent_);
if (this->is_failed()) {
ESP_LOGE(TAG, "Configuring RMT driver failed: %s (%s)", esp_err_to_name(this->error_code_),
this->error_string_.c_str());
void RemoteTransmitterComponent::digital_write(bool value) {
rmt_symbol_word_t symbol = {
.duration0 = 1,
.level0 = value,
.duration1 = 0,
.level1 = value,
rmt_transmit_config_t config;
memset(&config, 0, sizeof(config));
config.loop_count = 0;
config.flags.eot_level = value;
esp_err_t error = rmt_transmit(this->channel_, this->encoder_, &symbol, sizeof(symbol), &config);
if (error != ESP_OK) {
ESP_LOGW(TAG, "rmt_transmit failed: %s", esp_err_to_name(error));
this->status_set_warning();
error = rmt_tx_wait_all_done(this->channel_, -1);
ESP_LOGW(TAG, "rmt_tx_wait_all_done failed: %s", esp_err_to_name(error));
void RemoteTransmitterComponent::configure_rmt_() {
esp_err_t error;
gpio_set_direction(gpio_num_t(this->pin_->get_pin()), GPIO_MODE_OUTPUT); //-----------------------------added
if (!this->initialized_) {
bool open_drain = (this->pin_->get_flags() & gpio::FLAG_OPEN_DRAIN) != 0;
rmt_tx_channel_config_t channel;
memset(&channel, 0, sizeof(channel));
channel.clk_src = RMT_CLK_SRC_DEFAULT;
channel.resolution_hz = this->clock_resolution_;
channel.gpio_num = gpio_num_t(this->pin_->get_pin());
channel.mem_block_symbols = this->rmt_symbols_;
channel.trans_queue_depth = 1;
channel.flags.io_loop_back = open_drain;
channel.flags.io_od_mode = open_drain;
channel.flags.invert_out = 0;
channel.flags.with_dma = this->with_dma_;
channel.intr_priority = 0;
error = rmt_new_tx_channel(&channel, &this->channel_);
this->error_code_ = error;
if (error == ESP_ERR_NOT_FOUND) {
this->error_string_ = "out of RMT symbol memory";
} else {
this->error_string_ = "in rmt_new_tx_channel";
this->mark_failed();
return;
if (this->pin_->get_flags() & gpio::FLAG_PULLUP) {
gpio_pullup_en(gpio_num_t(this->pin_->get_pin()));
} else {
gpio_pullup_dis(gpio_num_t(this->pin_->get_pin()));
rmt_copy_encoder_config_t encoder;
memset(&encoder, 0, sizeof(encoder));
error = rmt_new_copy_encoder(&encoder, &this->encoder_);
this->error_string_ = "in rmt_new_copy_encoder";
return;
error = rmt_enable(this->channel_);
this->error_string_ = "in rmt_enable";
return;
this->digital_write(open_drain || this->inverted_);
this->initialized_ = true;
if (this->current_carrier_frequency_ == 0 || this->carrier_duty_percent_ == 100) {
error = rmt_apply_carrier(this->channel_, nullptr);
} else {
rmt_carrier_config_t carrier;
memset(&carrier, 0, sizeof(carrier));
carrier.frequency_hz = this->current_carrier_frequency_;
carrier.duty_cycle = (float) this->carrier_duty_percent_ / 100.0f;
carrier.flags.polarity_active_low = this->inverted_;
carrier.flags.always_on = 1;
error = rmt_apply_carrier(this->channel_, &carrier);
this->error_string_ = "in rmt_apply_carrier";
return;
void RemoteTransmitterComponent::send_internal(uint32_t send_times, uint32_t send_wait) {
configure_rmt_(); //---------------------------added
return;
if (this->current_carrier_frequency_ != this->temp_.get_carrier_frequency()) {
this->current_carrier_frequency_ = this->temp_.get_carrier_frequency();
this->rmt_temp_.clear();
this->rmt_temp_.reserve((this->temp_.get_data().size() + 1) / 2);
uint32_t rmt_i = 0;
rmt_symbol_word_t rmt_item;
for (int32_t val : this->temp_.get_data()) {
bool level = val >= 0;
if (!level)
val = -val;
val = this->from_microseconds_(static_cast<uint32_t>(val));
do {
int32_t item = std::min(val, int32_t(32767));
val -= item;
if (rmt_i % 2 == 0) {
rmt_item.level0 = static_cast<uint32_t>(level ^ this->inverted_);
rmt_item.duration0 = static_cast<uint32_t>(item);
} else {
rmt_item.level1 = static_cast<uint32_t>(level ^ this->inverted_);
rmt_item.duration1 = static_cast<uint32_t>(item);
this->rmt_temp_.push_back(rmt_item);
rmt_i++;
} while (val != 0);
if (rmt_i % 2 == 1) {
rmt_item.level1 = 0;
rmt_item.duration1 = 0;
if ((this->rmt_temp_.data() == nullptr) || this->rmt_temp_.empty()) {
ESP_LOGE(TAG, "Empty data");
return;
this->transmit_trigger_->trigger();
for (uint32_t i = 0; i < send_times; i++) {
config.flags.eot_level = this->eot_level_;
esp_err_t error = rmt_transmit(this->channel_, this->encoder_, this->rmt_temp_.data(),
this->rmt_temp_.size() * sizeof(rmt_symbol_word_t), &config);
} else {
this->status_clear_warning();
if (i + 1 < send_times)
delayMicroseconds(send_wait);
//------------------------------------------------added--------------------
if (this->channel_ != NULL) {
rmt_disable(this->channel_); // Disable the channel first
rmt_del_channel(this->channel_); // Delete the channel
this->channel_ = NULL; // Optional: clear the handle to prevent double deletion
gpio_set_direction(gpio_num_t(this->pin_->get_pin()), GPIO_MODE_INPUT);
this->initialized_ = false;
this->complete_trigger_->trigger();
} // namespace remote_transmitter
} // namespace esphome
#endif
