Sharing an automation "Table Top Wireless charger"
So I purchased one of these…
and created an automation using a zigbee plug to turn it on and off… so I figured I’d share and if anyone was interested I’m always happy to share seeing how I’ve gotten so much help from here from others and have used things I’ve found on here myself.
Here’s the automation, feel free to use, modify and share if you’d like!
What this does is detects the phone battery and turns on the charger if I’m home [that way the charger doesn’t turn on when I’m not home] and the phone battery goes below 50 and turns off if the battery reads 95% charged or I take it off the charger for more than 2 minutes. Yes I left the condition tag in the trigger section in case anyone wanted to add a condition.
Thank you all!
- alias: 15 - Auto Manage John's Phone Charging
  mode: single
  triggers:
    # Battery level changes
    - trigger: state
      entity_id: sensor.sm_f956u1_battery_level
    # Phone stops charging for 2 minutes
    - trigger: state
      entity_id: binary_sensor.sm_f956u1_is_charging
      to: "off"
      for: "00:02:00"
  condition: []
    - choose:
        # 🔌 BATTERY LOW - TURN ON CHARGER
        - conditions:
            - condition: trigger
            - condition: numeric_state
              below: 50
            - condition: state
              entity_id: device_tracker.john
              state: "home"
            - condition: state
              entity_id: switch.phone_charger
              state: "off"
          sequence:
            - action: switch.turn_on
            - action: tts.google_translate_say
                entity_id: media_player.sonos_five
                message: "Your phone battery is at {{ states('sensor.sm_f956u1_battery_level') }} percent. Turning on the phone charger so you can charge it."
        # 🔌 BATTERY FULL - TURN OFF CHARGER
        - conditions:
              above: 95
            - condition: state
              state: "on"
          sequence:
            - action: switch.turn_off
                message: "Your phone battery is at {{ states('sensor.sm_f956u1_battery_level') }} percent. Turning off the phone charger."
        # 🔌 PHONE STOPPED CHARGING - SAFETY SHUTOFF
        - conditions:
            - condition: state
              state: "on"
          sequence:
                message: "Your phone stopped charging for 2 minutes so I'm turning off the charger."
I added a few things to this… one is if temp gets too high [ Will NOT turn on unless temp below 95] it shuts off…
if phone is off charger for 2 minutes it shuts off…
  mode: single
  triggers:
    - trigger: state
    - trigger: state
      to: "off"
      for: "00:02:00"
    # 🔥 Battery temperature changes
    - trigger: state
      entity_id: sensor.sm_f956u1_battery_temperature
  condition: []
  actions:
    - choose:
        # 🔥 BATTERY TEMP OVER 100 - SAFETY SHUTOFF
        - conditions:
              above: 100
            - condition: state
              state: "on"
          sequence:
                message: >
                  Your phone battery temperature is
                  {{ states('sensor.sm_f956u1_battery_temperature') }}
                  degrees, which is over 100. Turning off the phone charger.
        # 🔒 Will NOT turn on unless temp below 95
        - conditions:
              below: 50
              below: 95 # 🔒 Thermal lockout
            - condition: state
              state: "home"
            - condition: state
              state: "off"
          sequence:
                message: >
                  percent. Turning on the phone charger, please charge your phone.
        - conditions:
              above: 95
            - condition: state
              state: "on"
          sequence:
                message: >
        - conditions:
            - condition: state
              state: "on"
          sequence:
                message: >
                  Your phone is off the charger for 2 minutes,
One more modification… if you don’t put the phone on the charger within 2 minutes it will now shut off the charger.
As it was if it was charging and you removed the phone for 2 minutes it would shut off… now it’ll do both!
  mode: single
  triggers:
    - trigger: state
    - trigger: state
      to: "off"
      for: "00:02:00"
    - trigger: state
    # 🔌 Charger turned on but phone not charging after 2 min
    - trigger: state
      to: "on"
      for: "00:02:00"
  condition: []
  actions:
    - choose:
        - conditions:
              above: 100
            - condition: state
              state: "on"
          sequence:
                message: >
                  "Your phone battery temperature is
                  degrees, which is over 100. Turning off the phone charger."
        # 🔌 CHARGER ON BUT PHONE NOT PLUGGED IN
        - conditions:
            - condition: state
              state: "off"
          sequence:
                message: >
                  "The charger has been on for two minutes but your phone is not charging.
                  Turning off the charger."
        - conditions:
              below: 60
              below: 95
            - condition: state
              state: "home"
            - condition: state
              state: "off"
          sequence:
                message: >
                  percent. Turning on the phone charger, please plug in your phone."
        - conditions:
              above: 95
            - condition: state
              state: "on"
          sequence:
                message: >
        - conditions:
            - condition: state
              state: "on"
          sequence:
                message: >
                  "Your phone has not been charging for two minutes,
