Shell command hastart
hi
could someone explain to me what is hastart ?
shell_command:
  ha_start: curl http://yourip:port/hastart
I assume it is an api call to start home assistant from the info you provided. Where did you find this code? You have any issues?
Hi
I’ve found the code from :
but it doesn’t work so i try to understand what it is and how it should work : i would appreciate if you can help me
