Shell command help
im trying to make a shell command but im keep getting this error
2017-11-07 15:35:31 ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block mapping
  in "/config/configuration.yaml", line 416, column 3
expected <block end>, but found '{'
  in "/config/configuration.yaml", line 418, column 9
2017-11-07 15:35:31 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block mapping
this is my confi yaml
shell_command:
  radio_test: 'curl -X POST -H "x-ha-access: MY_PASSWORD" \
    -H "Content-Type: application/json" \
    -d '{"state": "on", "attributes": {"friendly_name": "Radio"}}' \
    http://localhost:8123/api/states/binary_sensor.radio'
hope some can help thank you
Hi @Kem, not sure, but have you tried to write your command in one line?
I think this line-continuation will not work in yaml.
I think you have nested ' characters. The ' after the -d closes the one at the start of the command, so the yaml parser thinks the next { character is something it should parse.
I’m not sure how to escape that, but you might try a \ before the middle ones like
   -d \'{"state": "on", "attributes": {"friendly_name": "Radio"}}\'
thank you guys for taking time to help im still getting the same error with both of your suggestions
You could try removing the outside ' characters. I’m not sure they are necessary.
I would simplify the yaml by putting the curl command into its own shell script and then just call the shell script
thanks for the suggestion but i dont know anything about sell scripts it would be nice if you can post an example thank you again guys for your time
