I didn’t have
python_script: True
in configuration.yaml
Thanks for your Shellies Discovery Script
I didn’t have
python_script: True
in the HACS version: 0.11.1 you have changed the name of the plugin? I can only find Shelly smart home to install
Script is still in HACS.
I have a problem with the discovery script, it never launches for some reason. I can see in Node red that my shelly is sending shellies.announce to the MQTT broker, but that’s it. How can I troubleshoot the problem? Couldn’t find anything in the logs…
Would appreciate any help!
logger:
logs:
homeassistant.components.automation: info
MQTT Discovery
is enabled.discovery_prefix
in script configuration is the same as in MQTT configuration.From my configuration.yaml
mqtt:
broker: core-mosquitto
discovery: true
discovery_prefix: homeassistant
And the automation for the script:
- id: shellies_announce
alias: Shellies Announce
- platform: homeassistant
event: start
service: mqtt.publish
topic: shellies/command
payload: announce
- id: shellies_discovery
alias: Shellies Discovery
- platform: mqtt
topic: shellies/announce
service: python_script.shellies_discovery
data_template:
fw_ver: '{{ trigger.payload_json.fw_ver }}'
id: '{{ trigger.payload_json.id }}'
mac: '{{ trigger.payload_json.mac }}'
Wanted to say thank you for creating this.
I’m new to the HA community and this was one of my first attempts at setting up Shelly’s.
This automation made it so much easier once I worked through getting it installed.
Looks good. Do you have python_script:
in your configuration.yaml
Nice to hear that.
Yes I have.
I can see in the log that the first automation shellies_announce gets called on HASSIO start.
shellies_discovery automation doesn’t start while after shellies_announce?
What Shellies do you use?
They have updated firmware and correctly configured MQTT? Script works only if Shellies use default topics. Do you change topics in Shellies configuration?
Can you show topics that Shellies send to MQTT broker.
No.
I use Shelly 1 with the latest firmware.
After the fw update I did a factory reset and set the MQTT broker.
This is what the shelly sends to the topic shellies/announce:
{"id":"shelly1-2C8CD0","mac":"3C71BF2C8CD0","ip":"192.168.88.114","new_fw":false, "fw_ver":"20190711-084053/v1.5.0-hotfix4@3b4f7414"}
Yes I have
I have tried yesterday to manually trigger the discovery…
Do you have python_script.shellies_discovery
in Developer Tools -> Services?
How do you installed script? Maybe shellies_discovery.py
file is corrupted?
In my system script with your data works without problem:
shellies/announce {"id":"shelly1-2C8CD0","mac":"3C71BF2C8CD0","ip":"192.168.88.114","new_fw":false, "fw_ver":"20190711-084053/v1.5.0-hotfix4@3b4f7414"}
develop/switch/shelly1-2C8CD0-relay-0/config {"name":"Shelly1 2C8CD0 Relay 0","cmd_t":"~relay/0/command","stat_t":"~relay/0","pl_off":"off","pl_on":"on","avty_t":"~online","pl_avail":"true","pl_not_avail":"false","uniq_id":"shelly1-2C8CD0-relay-0","qos":"0","dev": {"ids": ["3C71BF2C8CD0"],"name":"Shelly1 2C8CD0","mdl":"Shelly1","sw":"20190711-084053/v1.5.0-hotfix4@3b4f7414","mf":"Allterco Robotics"},"~":"shellies/shelly1-2C8CD0/"}
develop/light/shelly1-2C8CD0-relay-0/config (null)
develop/fan/shelly1-2C8CD0-relay-0/config (null)
develop/binary_sensor/shelly1-2C8CD0-input-0/config {"name":"Shelly1 2C8CD0 Input 0","stat_t":"~input/0","pl_on":"1","pl_off":"0","avty_t":"~online","pl_avail":"true","pl_not_avail":"false","uniq_id":"shelly1-2C8CD0-input-0","qos":"0","dev": {"ids": ["3C71BF2C8CD0"],"name":"Shelly1 2C8CD0","mdl":"Shelly1","sw":"20190711-084053/v1.5.0-hotfix4@3b4f7414","mf":"Allterco Robotics"},"~":"shellies/shelly1-2C8CD0/"}
develop/binary_sensor/shelly1-2C8CD0-longpush-0/config {"name":"Shelly1 2C8CD0 Longpush 0","stat_t":"~longpush/0","pl_on":"1","pl_off":"0","avty_t":"~online","pl_avail":"true","pl_not_avail":"false","uniq_id":"shelly1-2C8CD0-longpush-0","qos":"0","dev": {"ids": ["3C71BF2C8CD0"],"name":"Shelly1 2C8CD0","mdl":"Shelly1","sw":"20190711-084053/v1.5.0-hotfix4@3b4f7414","mf":"Allterco Robotics"},"~":"shellies/shelly1-2C8CD0/"}
Yes, I have.
I have installed the script with HACS.
Just copied the script to the config\python_scripts folder - no luck.
You have in MQTT configuration broker: core-mosquitto
. This is hass.io add-on? Script doesn’t work with embedded broker.
Honestly, I don’t know why it doesn’t work for you. Everything looks good. Without some information from log, I don’t know how I can help. Switch logger to debug and search for any information in the log.
Here is the info from the debug log (search for shelly_discovery):
019-07-16 07:41:25 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=python_script, service=shellies_discovery>
2019-07-16 07:41:26 DEBUG (MainThread) [homeassistant.helpers.restore_state] Created cache with ['automation.shellies_discovery', 'automation.shellies_announce', 'switch.shelly_za_ruter']
2019-07-16 07:41:26 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.shellies_discovery, old_state=None, new_state=<state automation.shellies_discovery=on; last_triggered=2019-07-14T13:52:11.968170+00:00, id=shellies_discovery, friendly_name=Shellies Discovery @ 2019-07-16T07:41:26.875992+00:00>>
2019-07-16 07:41:26 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=group, service=set, service_data=object_id=all_automations, name=all automations, visible=False, entities=['automation.shellies_announce', 'automation.shellies_discovery']>
2019-07-16 07:41:26 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_automations, old_state=None, new_state=<state group.all_automations=on; entity_id=('automation.shellies_announce', 'automation.shellies_discovery'), order=0, auto=True, friendly_name=all automations, hidden=True @ 2019-07-16T07:41:26.919510+00:00>>
2019-07-16 07:42:06 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.548165170008] Sending {'id': 6, 'type': 'result', 'success': True, 'result': [<state sun.sun=above_horizon; next_dawn=2019-07-17T02:44:43+00:00, next_dusk=2019-07-16T19:23:03+00:00, next_midnight=2019-07-16T23:03:29+00:00, next_noon=2019-07-16T11:03:20+00:00, next_rising=2019-07-17T03:21:25+00:00, next_setting=2019-07-16T18:46:14+00:00, elevation=42.39, azimuth=103.36, rising=True, friendly_name=Sun @ 2019-07-16T07:41:24.978463+00:00>, <state automation.shellies_discovery=on; last_triggered=2019-07-14T13:52:11.968170+00:00, id=shellies_discovery, friendly_name=Shellies Discovery @ 2019-07-16T07:41:26.875992+00:00>, <state automation.shellies_announce=on; last_triggered=2019-07-16T07:42:01.885579+00:00, id=shellies_announce, friendly_name=Shellies Announce @ 2019-07-16T07:41:26.880243+00:00>, <state group.all_automations=on; entity_id=('automation.shellies_announce', 'automation.shellies_discovery'), order=0, auto=True, friendly_name=all automations, hidden=True @ 2019-07-16T07:41:26.919510+00:00>, <state binary_sensor.ping_binary_sensor=on; round_trip_time_avg=35.261, round_trip_time_max=39.869, round_trip_time_mdev=, round_trip_time_min=27.732, friendly_name=Ping Binary sensor, device_class=connectivity @ 2019-07-16T07:41:30.911429+00:00>, <state sensor.dark_sky_summary=Clear; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary, icon=mdi:weather-sunny, entity_picture=/static/images/darksky/weather-sunny.svg @ 2019-07-16T07:42:00.836613+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_3d=26.0; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 3d, icon=mdi:thermometer @ 2019-07-16T07:42:00.884210+00:00>, <state sensor.dark_sky_uv_index_5d=6; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 5d, icon=mdi:weather-sunny @ 2019-07-16T07:42:00.976283+00:00>, <state sensor.dark_sky_summary_2d=Possible light rain in the afternoon and evening.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary 2d, icon=mdi:weather-pouring, entity_picture=/static/images/darksky/weather-pouring.svg @ 2019-07-16T07:42:00.989289+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_4d=29.4; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 4d, icon=mdi:thermometer @ 2019-07-16T07:42:00.997069+00:00>, <state sensor.dark_sky_daily_summary=Light rain on Thursday and Friday, with high temperatures bottoming out at 24°C on Thursday.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Daily Summary, icon=mdi:weather-pouring, entity_picture=/static/images/darksky/weather-pouring.svg @ 2019-07-16T07:42:01.002136+00:00>, <state sensor.dark_sky_icon_3d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 3d @ 2019-07-16T07:42:01.008158+00:00>, <state sensor.dark_sky_summary_1d=Partly cloudy throughout the day.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary 1d, icon=mdi:weather-partlycloudy, entity_picture=/static/images/darksky/weather-partlycloudy.svg @ 2019-07-16T07:42:01.013525+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_5d=30.4; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.021079+00:00>, <state sensor.dark_sky_pressure=1014.6; attribution=Powered by Dark Sky, unit_of_measurement=mbar, friendly_name=Dark Sky Pressure, icon=mdi:gauge @ 2019-07-16T07:42:01.045129+00:00>, <state sensor.dark_sky_summary_3d=Overcast throughout the day.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary 3d, icon=mdi:weather-pouring, entity_picture=/static/images/darksky/weather-pouring.svg @ 2019-07-16T07:42:01.052077+00:00>, <state sensor.dark_sky_overnight_low_apparent_temperature_0d=14.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Apparent Temperature 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.063860+00:00>, <state sensor.dark_sky_pressure_0d=1014.0; attribution=Powered by Dark Sky, unit_of_measurement=mbar, friendly_name=Dark Sky Pressure 0d, icon=mdi:gauge @ 2019-07-16T07:42:01.070546+00:00>, <state sensor.dark_sky_summary_4d=Partly cloudy throughout the day.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary 4d, icon=mdi:weather-sunny, entity_picture=/static/images/darksky/weather-sunny.svg @ 2019-07-16T07:42:01.101070+00:00>, <state sensor.dark_sky_overnight_low_apparent_temperature_1d=16.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Apparent Temperature 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.128111+00:00>, <state sensor.dark_sky_pressure_1d=1013.2; attribution=Powered by Dark Sky, unit_of_measurement=mbar, friendly_name=Dark Sky Pressure 1d, icon=mdi:gauge @ 2019-07-16T07:42:01.137424+00:00>, <state sensor.dark_sky_icon_2d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 2d @ 2019-07-16T07:42:01.145845+00:00>, <state sensor.dark_sky_summary_5d=Mostly cloudy throughout the day.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary 5d, icon=mdi:weather-partlycloudy, entity_picture=/static/images/darksky/weather-partlycloudy.svg @ 2019-07-16T07:42:01.150833+00:00>, <state sensor.dark_sky_overnight_low_apparent_temperature_2d=15.4; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Apparent Temperature 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.155966+00:00>, <state sensor.dark_sky_pressure_2d=1012.0; attribution=Powered by Dark Sky, unit_of_measurement=mbar, friendly_name=Dark Sky Pressure 2d, icon=mdi:gauge @ 2019-07-16T07:42:01.161013+00:00>, <state sensor.dark_sky_nearest_storm_distance=unknown; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Nearest Storm Distance, icon=mdi:weather-lightning @ 2019-07-16T07:42:01.165990+00:00>, <state sensor.dark_sky_overnight_low_apparent_temperature_3d=16.3; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Apparent Temperature 3d, icon=mdi:thermometer @ 2019-07-16T07:42:01.171111+00:00>, <state sensor.dark_sky_pressure_3d=1013.8; attribution=Powered by Dark Sky, unit_of_measurement=mbar, friendly_name=Dark Sky Pressure 3d, icon=mdi:gauge @ 2019-07-16T07:42:01.176216+00:00>, <state sensor.dark_sky_nearest_storm_bearing=unknown; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Nearest Storm Bearing, icon=mdi:weather-lightning @ 2019-07-16T07:42:01.181300+00:00>, <state sensor.dark_sky_overnight_low_apparent_temperature_4d=17.9; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Apparent Temperature 4d, icon=mdi:thermometer @ 2019-07-16T07:42:01.186614+00:00>, <state sensor.dark_sky_pressure_4d=1016.2; attribution=Powered by Dark Sky, unit_of_measurement=mbar, friendly_name=Dark Sky Pressure 4d, icon=mdi:gauge @ 2019-07-16T07:42:01.191722+00:00>, <state sensor.dark_sky_humidity=78.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity, icon=mdi:water-percent @ 2019-07-16T07:42:01.196754+00:00>, <state sensor.dark_sky_overnight_low_apparent_temperature_5d=19.2; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Apparent Temperature 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.202093+00:00>, <state sensor.dark_sky_pressure_5d=1017.6; attribution=Powered by Dark Sky, unit_of_measurement=mbar, friendly_name=Dark Sky Pressure 5d, icon=mdi:gauge @ 2019-07-16T07:42:01.207156+00:00>, <state sensor.dark_sky_humidity_1d=67.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 1d, icon=mdi:water-percent @ 2019-07-16T07:42:01.212212+00:00>, <state sensor.dark_sky_wind_speed=2.03; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed, icon=mdi:weather-windy @ 2019-07-16T07:42:01.217184+00:00>, <state sensor.dark_sky_visibility=10.003; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility, icon=mdi:eye @ 2019-07-16T07:42:01.222177+00:00>, <state sensor.dark_sky_summary_0d=Clear throughout the day.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary 0d, icon=mdi:weather-sunny, entity_picture=/static/images/darksky/weather-sunny.svg @ 2019-07-16T07:42:01.227173+00:00>, <state sensor.dark_sky_humidity_2d=80.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 2d, icon=mdi:water-percent @ 2019-07-16T07:42:01.232378+00:00>, <state sensor.dark_sky_wind_speed_0d=1.49; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 0d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.237420+00:00>, <state sensor.dark_sky_visibility_0d=13.224; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 0d, icon=mdi:eye @ 2019-07-16T07:42:01.242865+00:00>, <state sensor.dark_sky_humidity_0d=73.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 0d, icon=mdi:water-percent @ 2019-07-16T07:42:01.248463+00:00>, <state sensor.dark_sky_humidity_3d=79.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 3d, icon=mdi:water-percent @ 2019-07-16T07:42:01.253736+00:00>, <state sensor.dark_sky_wind_speed_1d=1.12; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 1d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.258981+00:00>, <state sensor.dark_sky_visibility_1d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 1d, icon=mdi:eye @ 2019-07-16T07:42:01.264158+00:00>, <state sensor.dark_sky_icon_1d=partly-cloudy-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 1d @ 2019-07-16T07:42:01.270876+00:00>, <state sensor.dark_sky_icon_4d=clear-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 4d @ 2019-07-16T07:42:01.279480+00:00>, <state sensor.dark_sky_humidity_4d=73.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 4d, icon=mdi:water-percent @ 2019-07-16T07:42:01.287177+00:00>, <state sensor.dark_sky_wind_speed_2d=1; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 2d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.295350+00:00>, <state sensor.dark_sky_visibility_2d=15.158; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 2d, icon=mdi:eye @ 2019-07-16T07:42:01.300978+00:00>, <state sensor.dark_sky_humidity_5d=68.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 5d, icon=mdi:water-percent @ 2019-07-16T07:42:01.306771+00:00>, <state sensor.dark_sky_wind_speed_3d=0.81; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 3d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.314403+00:00>, <state sensor.dark_sky_visibility_3d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 3d, icon=mdi:eye @ 2019-07-16T07:42:01.320294+00:00>, <state sensor.dark_sky_temperature=18.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Temperature, icon=mdi:thermometer @ 2019-07-16T07:42:01.327747+00:00>, <state sensor.dark_sky_wind_speed_4d=1.03; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 4d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.335533+00:00>, <state sensor.dark_sky_visibility_4d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 4d, icon=mdi:eye @ 2019-07-16T07:42:01.344085+00:00>, <state sensor.dark_sky_wind_speed_5d=1.31; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 5d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.349357+00:00>, <state sensor.dark_sky_daytime_high_temperature_0d=25.7; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.354767+00:00>, <state sensor.dark_sky_visibility_5d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 5d, icon=mdi:eye @ 2019-07-16T07:42:01.360240+00:00>, <state sensor.dark_sky_daytime_high_temperature_1d=27.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.365711+00:00>, <state sensor.dark_sky_wind_bearing=189; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing, icon=mdi:compass @ 2019-07-16T07:42:01.371215+00:00>, <state sensor.dark_sky_daytime_high_temperature_2d=23.8; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.376741+00:00>, <state sensor.dark_sky_wind_bearing_0d=45; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 0d, icon=mdi:compass @ 2019-07-16T07:42:01.382222+00:00>, <state sensor.dark_sky_icon_0d=clear-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 0d @ 2019-07-16T07:42:01.387477+00:00>, <state sensor.dark_sky_daytime_high_temperature_3d=25.9; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 3d, icon=mdi:thermometer @ 2019-07-16T07:42:01.393059+00:00>, <state sensor.dark_sky_wind_bearing_1d=175; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 1d, icon=mdi:compass @ 2019-07-16T07:42:01.399128+00:00>, <state sensor.dark_sky_daytime_high_temperature_4d=28.9; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 4d, icon=mdi:thermometer @ 2019-07-16T07:42:01.405414+00:00>, <state sensor.dark_sky_wind_bearing_2d=263; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 2d, icon=mdi:compass @ 2019-07-16T07:42:01.411075+00:00>, <state sensor.dark_sky_daytime_high_temperature_5d=29.6; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.416703+00:00>, <state sensor.dark_sky_wind_bearing_3d=260; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 3d, icon=mdi:compass @ 2019-07-16T07:42:01.422312+00:00>, <state sensor.dark_sky_icon_5d=partly-cloudy-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 5d @ 2019-07-16T07:42:01.427883+00:00>, <state sensor.dark_sky_overnight_low_temperature_0d=14.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.433871+00:00>, <state sensor.dark_sky_wind_bearing_4d=237; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 4d, icon=mdi:compass @ 2019-07-16T07:42:01.439490+00:00>, <state sensor.dark_sky_overnight_low_temperature_1d=16.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.445338+00:00>, <state sensor.dark_sky_wind_bearing_5d=8; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 5d, icon=mdi:compass @ 2019-07-16T07:42:01.451526+00:00>, <state sensor.dark_sky_overnight_low_temperature_2d=15.3; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.457195+00:00>, <state sensor.dark_sky_precip=unknown; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.462795+00:00>, <state sensor.dark_sky_overnight_low_temperature_3d=16.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 3d, icon=mdi:thermometer @ 2019-07-16T07:42:01.468431+00:00>, <state sensor.dark_sky_precip_0d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 0d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.474087+00:00>, <state sensor.dark_sky_overnight_low_temperature_4d=17.8; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 4d, icon=mdi:thermometer @ 2019-07-16T07:42:01.479854+00:00>, <state sensor.dark_sky_precip_1d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 1d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.485519+00:00>, <state sensor.dark_sky_overnight_low_temperature_5d=18.8; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.491418+00:00>, <state sensor.dark_sky_precip_2d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 2d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.497267+00:00>, <state sensor.dark_sky_apparent_temperature=18.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Apparent Temperature, icon=mdi:thermometer @ 2019-07-16T07:42:01.503001+00:00>, <state sensor.dark_sky_precip_3d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 3d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.508788+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_0d=25.7; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.514784+00:00>, <state sensor.dark_sky_precip_4d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 4d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.520448+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_1d=27.3; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.526493+00:00>, <state sensor.dark_sky_precip_5d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 5d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.532288+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_2d=23.9; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.538207+00:00>, <state sensor.dark_sky_precip_probability=0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability, icon=mdi:water-percent @ 2019-07-16T07:42:01.544036+00:00>, <state sensor.dark_sky_precip_probability_0d=4.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 0d, icon=mdi:water-percent @ 2019-07-16T07:42:01.549832+00:00>, <state sensor.dark_sky_precip_probability_1d=7.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 1d, icon=mdi:water-percent @ 2019-07-16T07:42:01.556534+00:00>, <state sensor.dark_sky_precip_probability_2d=67.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 2d, icon=mdi:water-percent @ 2019-07-16T07:42:01.562525+00:00>, <state sensor.dark_sky_precip_probability_3d=38.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 3d, icon=mdi:water-percent @ 2019-07-16T07:42:01.569723+00:00>, <state sensor.dark_sky_precip_probability_4d=10.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 4d, icon=mdi:water-percent @ 2019-07-16T07:42:01.575643+00:00>, <state sensor.dark_sky_precip_probability_5d=7.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 5d, icon=mdi:water-percent @ 2019-07-16T07:42:01.581712+00:00>, <state sensor.dark_sky_precip_accumulation_0d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 0d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.587559+00:00>, <state sensor.dark_sky_precip_accumulation_1d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 1d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.593640+00:00>, <state sensor.dark_sky_precip_accumulation_2d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 2d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.599668+00:00>, <state sensor.dark_sky_precip_accumulation_3d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 3d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.605678+00:00>, <state sensor.dark_sky_precip_accumulation_4d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 4d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.611750+00:00>, <state sensor.dark_sky_precip_accumulation_5d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 5d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.617804+00:00>, <state sensor.dark_sky_precip_intensity=0; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.623786+00:00>, <state sensor.dark_sky_precip_intensity_0d=0.002; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 0d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.629974+00:00>, <state sensor.dark_sky_precip_intensity_1d=0.0019; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 1d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.635908+00:00>, <state sensor.dark_sky_precip_intensity_2d=0.1373; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 2d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.641878+00:00>, <state sensor.dark_sky_precip_intensity_3d=0.0195; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 3d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.647917+00:00>, <state sensor.dark_sky_precip_intensity_4d=0.0068; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 4d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.653974+00:00>, <state sensor.dark_sky_precip_intensity_5d=0.0032; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 5d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.660025+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_0d=0.0062; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.666108+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_1d=0.0104; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.672265+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_2d=0.7411; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.678418+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_3d=0.1222; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 3d, icon=mdi:thermometer @ 2019-07-16T07:42:01.684648+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_4d=0.078; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 4d, icon=mdi:thermometer @ 2019-07-16T07:42:01.691059+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_5d=0.0094; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.697267+00:00>, <state sensor.dark_sky_uv_index=4; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.703504+00:00>, <state sensor.dark_sky_icon=clear-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon @ 2019-07-16T07:42:01.709823+00:00>, <state sensor.dark_sky_uv_index_0d=8; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 0d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.715957+00:00>, <state sensor.dark_sky_uv_index_1d=8; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 1d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.722138+00:00>, <state sensor.dark_sky_uv_index_2d=7; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 2d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.728276+00:00>, <state sensor.dark_sky_uv_index_3d=4; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 3d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.734847+00:00>, <state sensor.dark_sky_uv_index_4d=8; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 4d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.741018+00:00>, <state sensor.hacs=unknown; unit_of_measurement=pending update(s), friendly_name=hacs, icon=mdi:package @ 2019-07-16T07:42:01.760710+00:00>]}
and a second part
16T07:42:01.217184+00:00>, <state sensor.dark_sky_visibility=10.003; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility, icon=mdi:eye @ 2019-07-16T07:42:01.222177+00:00>, <state sensor.dark_sky_summary_0d=Clear throughout the day.; attribution=Powered by Dark Sky, friendly_name=Dark Sky Summary 0d, icon=mdi:weather-sunny, entity_picture=/static/images/darksky/weather-sunny.svg @ 2019-07-16T07:42:01.227173+00:00>, <state sensor.dark_sky_humidity_2d=80.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 2d, icon=mdi:water-percent @ 2019-07-16T07:42:01.232378+00:00>, <state sensor.dark_sky_wind_speed_0d=1.49; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 0d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.237420+00:00>, <state sensor.dark_sky_visibility_0d=13.224; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 0d, icon=mdi:eye @ 2019-07-16T07:42:01.242865+00:00>, <state sensor.dark_sky_humidity_0d=73.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 0d, icon=mdi:water-percent @ 2019-07-16T07:42:01.248463+00:00>, <state sensor.dark_sky_humidity_3d=79.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 3d, icon=mdi:water-percent @ 2019-07-16T07:42:01.253736+00:00>, <state sensor.dark_sky_wind_speed_1d=1.12; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 1d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.258981+00:00>, <state sensor.dark_sky_visibility_1d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 1d, icon=mdi:eye @ 2019-07-16T07:42:01.264158+00:00>, <state sensor.dark_sky_icon_1d=partly-cloudy-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 1d @ 2019-07-16T07:42:01.270876+00:00>, <state sensor.dark_sky_icon_4d=clear-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 4d @ 2019-07-16T07:42:01.279480+00:00>, <state sensor.dark_sky_humidity_4d=73.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 4d, icon=mdi:water-percent @ 2019-07-16T07:42:01.287177+00:00>, <state sensor.dark_sky_wind_speed_2d=1; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 2d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.295350+00:00>, <state sensor.dark_sky_visibility_2d=15.158; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 2d, icon=mdi:eye @ 2019-07-16T07:42:01.300978+00:00>, <state sensor.dark_sky_humidity_5d=68.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Humidity 5d, icon=mdi:water-percent @ 2019-07-16T07:42:01.306771+00:00>, <state sensor.dark_sky_wind_speed_3d=0.81; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 3d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.314403+00:00>, <state sensor.dark_sky_visibility_3d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 3d, icon=mdi:eye @ 2019-07-16T07:42:01.320294+00:00>, <state sensor.dark_sky_temperature=18.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Temperature, icon=mdi:thermometer @ 2019-07-16T07:42:01.327747+00:00>, <state sensor.dark_sky_wind_speed_4d=1.03; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 4d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.335533+00:00>, <state sensor.dark_sky_visibility_4d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 4d, icon=mdi:eye @ 2019-07-16T07:42:01.344085+00:00>, <state sensor.dark_sky_wind_speed_5d=1.31; attribution=Powered by Dark Sky, unit_of_measurement=m/s, friendly_name=Dark Sky Wind Speed 5d, icon=mdi:weather-windy @ 2019-07-16T07:42:01.349357+00:00>, <state sensor.dark_sky_daytime_high_temperature_0d=25.7; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.354767+00:00>, <state sensor.dark_sky_visibility_5d=16.093; attribution=Powered by Dark Sky, unit_of_measurement=km, friendly_name=Dark Sky Visibility 5d, icon=mdi:eye @ 2019-07-16T07:42:01.360240+00:00>, <state sensor.dark_sky_daytime_high_temperature_1d=27.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.365711+00:00>, <state sensor.dark_sky_wind_bearing=189; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing, icon=mdi:compass @ 2019-07-16T07:42:01.371215+00:00>, <state sensor.dark_sky_daytime_high_temperature_2d=23.8; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.376741+00:00>, <state sensor.dark_sky_wind_bearing_0d=45; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 0d, icon=mdi:compass @ 2019-07-16T07:42:01.382222+00:00>, <state sensor.dark_sky_icon_0d=clear-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 0d @ 2019-07-16T07:42:01.387477+00:00>, <state sensor.dark_sky_daytime_high_temperature_3d=25.9; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 3d, icon=mdi:thermometer @ 2019-07-16T07:42:01.393059+00:00>, <state sensor.dark_sky_wind_bearing_1d=175; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 1d, icon=mdi:compass @ 2019-07-16T07:42:01.399128+00:00>, <state sensor.dark_sky_daytime_high_temperature_4d=28.9; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 4d, icon=mdi:thermometer @ 2019-07-16T07:42:01.405414+00:00>, <state sensor.dark_sky_wind_bearing_2d=263; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 2d, icon=mdi:compass @ 2019-07-16T07:42:01.411075+00:00>, <state sensor.dark_sky_daytime_high_temperature_5d=29.6; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Temperature 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.416703+00:00>, <state sensor.dark_sky_wind_bearing_3d=260; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 3d, icon=mdi:compass @ 2019-07-16T07:42:01.422312+00:00>, <state sensor.dark_sky_icon_5d=partly-cloudy-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon 5d @ 2019-07-16T07:42:01.427883+00:00>, <state sensor.dark_sky_overnight_low_temperature_0d=14.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.433871+00:00>, <state sensor.dark_sky_wind_bearing_4d=237; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 4d, icon=mdi:compass @ 2019-07-16T07:42:01.439490+00:00>, <state sensor.dark_sky_overnight_low_temperature_1d=16.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.445338+00:00>, <state sensor.dark_sky_wind_bearing_5d=8; attribution=Powered by Dark Sky, unit_of_measurement=°, friendly_name=Dark Sky Wind Bearing 5d, icon=mdi:compass @ 2019-07-16T07:42:01.451526+00:00>, <state sensor.dark_sky_overnight_low_temperature_2d=15.3; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.457195+00:00>, <state sensor.dark_sky_precip=unknown; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.462795+00:00>, <state sensor.dark_sky_overnight_low_temperature_3d=16.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 3d, icon=mdi:thermometer @ 2019-07-16T07:42:01.468431+00:00>, <state sensor.dark_sky_precip_0d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 0d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.474087+00:00>, <state sensor.dark_sky_overnight_low_temperature_4d=17.8; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 4d, icon=mdi:thermometer @ 2019-07-16T07:42:01.479854+00:00>, <state sensor.dark_sky_precip_1d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 1d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.485519+00:00>, <state sensor.dark_sky_overnight_low_temperature_5d=18.8; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Overnight Low Temperature 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.491418+00:00>, <state sensor.dark_sky_precip_2d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 2d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.497267+00:00>, <state sensor.dark_sky_apparent_temperature=18.1; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Apparent Temperature, icon=mdi:thermometer @ 2019-07-16T07:42:01.503001+00:00>, <state sensor.dark_sky_precip_3d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 3d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.508788+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_0d=25.7; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.514784+00:00>, <state sensor.dark_sky_precip_4d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 4d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.520448+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_1d=27.3; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.526493+00:00>, <state sensor.dark_sky_precip_5d=rain; attribution=Powered by Dark Sky, friendly_name=Dark Sky Precip 5d, icon=mdi:weather-pouring @ 2019-07-16T07:42:01.532288+00:00>, <state sensor.dark_sky_daytime_high_apparent_temperature_2d=23.9; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Dark Sky Daytime High Apparent Temperature 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.538207+00:00>, <state sensor.dark_sky_precip_probability=0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability, icon=mdi:water-percent @ 2019-07-16T07:42:01.544036+00:00>, <state sensor.dark_sky_precip_probability_0d=4.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 0d, icon=mdi:water-percent @ 2019-07-16T07:42:01.549832+00:00>, <state sensor.dark_sky_precip_probability_1d=7.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 1d, icon=mdi:water-percent @ 2019-07-16T07:42:01.556534+00:00>, <state sensor.dark_sky_precip_probability_2d=67.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 2d, icon=mdi:water-percent @ 2019-07-16T07:42:01.562525+00:00>, <state sensor.dark_sky_precip_probability_3d=38.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 3d, icon=mdi:water-percent @ 2019-07-16T07:42:01.569723+00:00>, <state sensor.dark_sky_precip_probability_4d=10.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 4d, icon=mdi:water-percent @ 2019-07-16T07:42:01.575643+00:00>, <state sensor.dark_sky_precip_probability_5d=7.0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Dark Sky Precip Probability 5d, icon=mdi:water-percent @ 2019-07-16T07:42:01.581712+00:00>, <state sensor.dark_sky_precip_accumulation_0d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 0d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.587559+00:00>, <state sensor.dark_sky_precip_accumulation_1d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 1d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.593640+00:00>, <state sensor.dark_sky_precip_accumulation_2d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 2d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.599668+00:00>, <state sensor.dark_sky_precip_accumulation_3d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 3d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.605678+00:00>, <state sensor.dark_sky_precip_accumulation_4d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 4d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.611750+00:00>, <state sensor.dark_sky_precip_accumulation_5d=unknown; attribution=Powered by Dark Sky, unit_of_measurement=cm, friendly_name=Dark Sky Precip Accumulation 5d, icon=mdi:weather-snowy @ 2019-07-16T07:42:01.617804+00:00>, <state sensor.dark_sky_precip_intensity=0; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.623786+00:00>, <state sensor.dark_sky_precip_intensity_0d=0.002; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 0d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.629974+00:00>, <state sensor.dark_sky_precip_intensity_1d=0.0019; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 1d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.635908+00:00>, <state sensor.dark_sky_precip_intensity_2d=0.1373; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 2d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.641878+00:00>, <state sensor.dark_sky_precip_intensity_3d=0.0195; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 3d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.647917+00:00>, <state sensor.dark_sky_precip_intensity_4d=0.0068; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 4d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.653974+00:00>, <state sensor.dark_sky_precip_intensity_5d=0.0032; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Precip Intensity 5d, icon=mdi:weather-rainy @ 2019-07-16T07:42:01.660025+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_0d=0.0062; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 0d, icon=mdi:thermometer @ 2019-07-16T07:42:01.666108+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_1d=0.0104; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 1d, icon=mdi:thermometer @ 2019-07-16T07:42:01.672265+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_2d=0.7411; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 2d, icon=mdi:thermometer @ 2019-07-16T07:42:01.678418+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_3d=0.1222; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 3d, icon=mdi:thermometer @ 2019-07-16T07:42:01.684648+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_4d=0.078; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 4d, icon=mdi:thermometer @ 2019-07-16T07:42:01.691059+00:00>, <state sensor.dark_sky_daily_max_precip_intensity_5d=0.0094; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Dark Sky Daily Max Precip Intensity 5d, icon=mdi:thermometer @ 2019-07-16T07:42:01.697267+00:00>, <state sensor.dark_sky_uv_index=4; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.703504+00:00>, <state sensor.dark_sky_icon=clear-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon @ 2019-07-16T07:42:01.709823+00:00>, <state sensor.dark_sky_uv_index_0d=8; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 0d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.715957+00:00>, <state sensor.dark_sky_uv_index_1d=8; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 1d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.722138+00:00>, <state sensor.dark_sky_uv_index_2d=7; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 2d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.728276+00:00>, <state sensor.dark_sky_uv_index_3d=4; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 3d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.734847+00:00>, <state sensor.dark_sky_uv_index_4d=8; attribution=Powered by Dark Sky, unit_of_measurement=UV index, friendly_name=Dark Sky UV Index 4d, icon=mdi:weather-sunny @ 2019-07-16T07:42:01.741018+00:00>, <state sensor.hacs=1; unit_of_measurement=pending update(s), friendly_name=hacs, icon=mdi:package @ 2019-07-16T07:42:32.007755+00:00>]}
and a third
2019-07-16 07:42:35 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.548189829496] Sending {'id': 11, 'type': 'result', 'success': True, 'result': {'persistent_notification': {'create': {'description': 'Show a notification in the frontend.', 'fields': OrderedDict([('message', OrderedDict([('description', 'Message body of the notification. [Templates accepted]'), ('example', 'Please check your configuration.yaml.')])), ('title', OrderedDict([('description', 'Optional title for your notification. [Optional, Templates accepted]'), ('example', 'Test notification')])), ('notification_id', OrderedDict([('description', 'Target ID of the notification, will replace a notification with the same Id. [Optional]'), ('example', 1234)]))])}, 'dismiss': {'description': 'Remove a notification from the frontend.', 'fields': OrderedDict([('notification_id', OrderedDict([('description', 'Target ID of the notification, which should be removed. [Required]'), ('example', 1234)]))])}, 'mark_read': {'description': 'Mark a notification read.', 'fields': OrderedDict([('notification_id', OrderedDict([('description', 'Target ID of the notification, which should be mark read. [Required]'), ('example', 1234)]))])}}, 'homeassistant': {'turn_off': {'description': 'Generic service to turn devices off under any domain. Same usage as the light.turn_on, switch.turn_on, etc. services.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'The entity_id of the device to turn off.'), ('example', 'light.living_room')]))])}, 'turn_on': {'description': 'Generic service to turn devices on under any domain. Same usage as the light.turn_on, switch.turn_on, etc. services.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'The entity_id of the device to turn on.'), ('example', 'light.living_room')]))])}, 'toggle': {'description': 'Generic service to toggle devices on/off under any domain. Same usage as the light.turn_on, switch.turn_on, etc. services.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'The entity_id of the device to toggle on/off.'), ('example', 'light.living_room')]))])}, 'stop': {'description': 'Stop the Home Assistant service.', 'fields': {}}, 'restart': {'description': 'Restart the Home Assistant service.', 'fields': {}}, 'check_config': {'description': 'Check the Home Assistant configuration files for errors. Errors will be displayed in the Home Assistant log.', 'fields': {}}, 'update_entity': {'description': 'Force one or more entities to update its data', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'One or multiple entity_ids to update. Can be a list.'), ('example', 'light.living_room')]))])}, 'reload_core_config': {'description': 'Reload the core configuration.', 'fields': {}}, 'set_location': {'description': '', 'fields': {}}}, 'logger': {'set_default_level': {'description': 'Set the default log level for components.', 'fields': OrderedDict([('level', OrderedDict([('description', 'Default severity level. Possible values are notset, debug, info, warn, warning, error, fatal, critical'), ('example', 'debug')]))])}, 'set_level': {'description': 'Set log level for components.', 'fields': {}}}, 'system_log': {'clear': {'description': 'Clear all log entries.', 'fields': {}}, 'write': {'description': 'Write log entry.', 'fields': OrderedDict([('message', OrderedDict([('description', 'Message to log. [Required]'), ('example', 'Something went wrong')])), ('level', OrderedDict([('description', "Log level: debug, info, warning, error, critical. Defaults to 'error'."), ('example', 'debug')])), ('logger', OrderedDict([('description', "Logger name under which to log the message. Defaults to 'system_log.external'."), ('example', 'mycomponent.myplatform')]))])}}, 'recorder': {'purge': {'description': 'Start purge task - delete events and states older than x days, according to keep_days service data.', 'fields': OrderedDict([('keep_days', OrderedDict([('description', 'Number of history days to keep in database after purge. Value >= 0.'), ('example', 2)])), ('repack', OrderedDict([('description', 'Attempt to save disk space by rewriting the entire database file.'), ('example', True)]))])}}, 'group': {'reload': {'description': 'Reload group configuration.', 'fields': {}}, 'set': {'description': 'Create/Update a user group.', 'fields': OrderedDict([('object_id', OrderedDict([('description', 'Group id and part of entity id.'), ('example', 'test_group')])), ('name', OrderedDict([('description', 'Name of group'), ('example', 'My test group')])), ('view', OrderedDict([('description', 'Boolean for if the group is a view.'), ('example', True)])), ('icon', OrderedDict([('description', 'Name of icon for the group.'), ('example', 'mdi:camera')])), ('control', OrderedDict([('description', 'Value for control the group control.'), ('example', 'hidden')])), ('visible', OrderedDict([('description', 'If the group is visible on UI.'), ('example', True)])), ('entities', OrderedDict([('description', "List of all members in the group. Not compatible with 'delta'."), ('example', 'domain.entity_id1, domain.entity_id2')])), ('add_entities', OrderedDict([('description', 'List of members they will change on group listening.'), ('example', 'domain.entity_id1, domain.entity_id2')])), ('all', OrderedDict([('description', 'Enable this option if the group should only turn on when all entities are on.'), ('example', True)]))])}, 'remove': {'description': 'Remove a user group.', 'fields': OrderedDict([('object_id', OrderedDict([('description', 'Group id and part of entity id.'), ('example', 'test_group')]))])}, 'set_visibility': {'description': 'Hide or show a group.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to set value.'), ('example', 'group.travel')])), ('visible', OrderedDict([('description', 'True if group should be shown or False if it should be hidden.'), ('example', True)]))])}}, 'python_script': {'shellies_discovery': {'description': '', 'fields': {}}, 'reload': {'description': 'Reload all available python_scripts', 'fields': {}}}, 'script': {'reload': {'description': 'Reload all the available scripts', 'fields': {}}, 'turn_on': {'description': 'Turn on script', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of script to be turned on.'), ('example', 'script.arrive_home')]))])}, 'turn_off': {'description': 'Turn off script', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of script to be turned off.'), ('example', 'script.arrive_home')]))])}, 'toggle': {'description': 'Toggle script', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of script to be toggled.'), ('example', 'script.arrive_home')]))])}}, 'conversation': {'process': {'description': 'Launch a conversation from a transcribed text.', 'fields': OrderedDict([('text', OrderedDict([('description', 'Transcribed text'), ('example', 'Turn all lights on')]))])}}, 'automation': {'trigger': {'description': 'Trigger the action of an automation.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name of the automation to trigger.'), ('example', 'automation.notify_home')]))])}, 'reload': {'description': 'Reload the automation configuration.', 'fields': {}}, 'toggle': {'description': 'Toggle an automation.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name of the automation to toggle on/off.'), ('example', 'automation.notify_home')]))])}, 'turn_on': {'description': 'Enable an automation.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name of the automation to turn on.'), ('example', 'automation.notify_home')]))])}, 'turn_off': {'description': 'Disable an automation.', 'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name of the automation to turn off.'), ('example', 'automation.notify_home')]))])}}, 'mikrotik': {'run_script': {'description': 'Run script on RouterBoard', 'fields': OrderedDict([('name', OrderedDict([('description', 'Name of the saved script'), ('example', 'MySavedScript')]))])}}, 'mqtt': {'publish': {'description': 'Publish a message to an MQTT topic.', 'fields': OrderedDict([('topic', OrderedDict([('description', 'Topic to publish payload.'), ('example', '/homeassistant/hello')])), ('payload', OrderedDict([('description', 'Payload to publish.'), ('example', 'This is great')])), ('payload_template', OrderedDict([('description', 'Template to render as payload value. Ignored if payload given.'), ('example', "{{ states('sensor.temperature') }}")])), ('qos', OrderedDict([('description', 'Quality of Service to use.'), ('example', 2), ('values', [0, 1, 2]), ('default', 0)])), ('retain', OrderedDict([('description', 'If message should have the retain flag set.'), ('example', True), ('default', False)]))])}}, 'logbook': {'log': {'description': '', 'fields': {}}}, 'cloud': {'remote_connect': {'description': 'Make instance UI available outside over NabuCasa cloud.', 'fields': {}}, 'remote_disconnect': {'description': 'Disconnect UI from NabuCasa cloud.', 'fields': {}}}, 'tts': {'google_say': {'description': '', 'fields': {}}, 'clear_cache': {'description': 'Remove cache files and RAM cache.', 'fields': {}}}, 'hassio': {'addon_start': {'description': 'Start a HassIO docker addon.', 'fields': OrderedDict([('addon', OrderedDict([('description', 'Name of addon.'), ('example', 'smb_config')]))])}, 'addon_stop': {'description': 'Stop a HassIO docker addon.', 'fields': OrderedDict([('addon', OrderedDict([('description', 'Name of addon.'), ('example', 'smb_config')]))])}, 'addon_restart': {'description': '', 'fields': {}}, 'addon_stdin': {'description': '', 'fields': {}}, 'host_shutdown': {'description': 'Poweroff host computer.', 'fields': {}}, 'host_reboot': {'description': 'Reboot host computer.', 'fields': {}}, 'snapshot_full': {'description': '', 'fields': {}}, 'snapshot_partial': {'description': '', 'fields': {}}, 'restore_full': {'description': '', 'fields': {}}, 'restore_partial': {'description': '', 'fields': {}}}}}
