Shelly 1 binary_sensor does no change on wall switch change
I have a shelly 1 set up behind my light switch, but the binary_sensor doesn’t change whatever I do. I can measure the 230V or 0V on the shelly screw, dependent of the wall switch, so it must be set up correctly. Can anybody help?
The binary_sensor is always on. If I invert the GPIO pin, it simply is always of. Pullup doesn’t change anything either.
Is this a Shelly 1 flashed with ESPHome? If so, please paste your config file, properly formatted with the </> button.
My relevant section:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO5
    name: "Utility Room Light Switch"
…and that works fine:
Yes it is. My here is my config file:
substitutions:
  device_name: shelly1-bad-deckenlicht
  device_description: "Shelly1 Deckenlicht"
esphome:
esp8266:
  board: esp01_1m
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_encryption_key
ota:
  password: !secret ha_api_password
# Zeit von Home Assistant
time:
  - platform: homeassistant
# Buttons
button:
  # Restart ESP32 Butten
  - <<: !include common/button/restart_button.yaml
# Text-Sensor
text_sensor:
# IP-Adresse als Sensor
  - <<: !include common/text-sensor/ip-adresse.yaml
# Sensoren
  # WLAN Signalstärke
  - <<: !include common/sensor/wifi_strength.yaml
  # Betriebszeit
  - <<: !include common/sensor/uptime.yaml
# Device Specific Config
output:
  - platform: gpio
    pin: GPIO4
light:
  - platform: binary
    name: "${ort} Deckenlicht ${device_description}"
    output: shelly_1_relay
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO5
    name: "${ort} Schalter ${device_description}"
#    internal: true
    filters:
      - delayed_on_off: 50ms
    on_state:
        then:
          - if:
              condition:
                light.is_on: lightid
              then:
                - light.turn_on: lightid
              else:
                - light.turn_off: lightid
Hm, mine looks exactly alike. So it probably is defect, although it has never been used before, just lay around for a year. :thinking:
No, tried a different new shelly. Doesn’t work either. Is it a problem with the newest firmware?
If you’ve flashed ESPHome, it’s not running Shelly firmware.
How have you wired it? Can you post the startup logs from ESPHome?
It is the shelly. I flashed the original shelly firmware again and it isn’t working either. So I have two malfunctioning shellys. Thanks for your help.
@Troon Maybe try this?
  - platform: gpio
    pin:
      number: GPIO5
    # small delay to prevent debouncing
    filters:
    # config for state change of input button
    # When  wifi/api connected, use homeassistant.service
    # otherwise, use switch.turn_on/off shelly_relay
    on_state:
        then:
          - if:
              condition:
               and:
                 - wifi.connected:
                 - api.connected:
                 - switch.is_off: shelly_relay
              # turn_on light if wifi and api are connected and relay is off
              then:
                - homeassistant.service:
                    service: switch.turn_on
                      entity_id: switch.shelly1_masterbedroom
              # else, turn off
              else:
                - if:
                    condition:
                      and:
                        - wifi.connected:
                        - api.connected:
                        - switch.is_on: shelly_relay
                    # turn_off switch if wifi and api are connected and relay is on
                    then:
                          service: switch.turn_off
                    else:
                      if:
                        condition:
                        then:
                          - switch.turn_on: shelly_relay
                        else:
                          - switch.turn_off: shelly_relay
# Shelly 1 detached switch config with fallback in case of wifi or api fail
switch:
  - platform: gpio
    pin: GPIO4
    # after reboot, keep the relay off. this prevents light turning on after a power outage
    restore_mode: ALWAYS_OFF
And if you enable the web interface, you can also see if the input sensor is working :stuck_out_tongue:
# Enable Web server (optional).
web_server:
  port: 80
sorry, @dflvunoooooo i ment
Mine is working fine, thanks. :wink:
