Hello
I have a Shelly 1L but it had some connection issues. So i decided to try Esphome.
I first installed Tasmota and from there installed Esphome using Home Assistant with the default config and enabled encryption.
Now the problem is i replaced the default config with this config. but now i can upload because i dont have the encryption key.
Normaly you would fix this by reflashing the firmware and i tried it. I solderd some wires to the bottom side connector (i don’t have jumpers small enough for the connector), i used an esp32 as a 3.3V power supply and a usb to ttl converter. But after 2 hours of trying nothing.
I also tried resetting it by holding the bottom reset button for 10 seconds but it didn’t seem to do anything.
So what are my options here?
Any help is much appreciated.
