Shelly 2PM Gen1, 2, 3
After 5 years of using 10 Shelly 2.5 Gen1 devices for roller shutters control, today the 3rd one stopped working. Around a year ago, I had to replace another two Gen1 devices with Gen2. Now the third one is defect, which I should probably replace with Gen3.
Do you know if Gen3 improved anything to prevent these quality issues?
The problem is https://www.reddit.com/r/shellycloud/comments/13vys0w/signs_of_a_dying_shelly/
If not, which alternative, WiFi or Zigbee, would you recommend? The Gen3 comes with 3-year warranty but even so I would like a device with the longer lifespan, if one exists.
If you ever read Shelly tech details, you will find:
When you use inductive load like motors, add a snubber to smooth spikes.
