Shelly BLU Button 1 not found in BTHome
My two latest Shelly BLU Button1’s were not found by BTHome/Home Assistant.
After great advice from the forums (here and Shelly) I could integrate Shelly BLU buttons via BTHome, as they were found automatically once I had them added in the Shelly App. This did not work with the two latest ones I wanted to integrate, they are not shown.
Is there a trick to force them to be found and/or how can I add them manually in BTHome. So far I only get to Add Entry with the message “No devices found on the network“ and no option to add something manually.
Btw, the buttons work in Shelly but not to be found in Home Assistant (as my previous ones were, though).
Thanks!
Same problem for me, BTHome integration just says „No devices found in Network“
That is strange. They should be discovered automatically once you click the button. Can you create an issue on github and post the debug logging after enabling debugging for the Bluetooth integration?
same problem here
anyone solved this?
i worked before i updated to the latest version of HA
i can still see the button in the shelly app and its trigered
Please open an issue on github if you still have this issue, along with some debug logging for the BLUETOOTH integration.
I experienced this issue with 3 out of 8 of my latest Shelly BLU Buttons. 5 out of the 8 detected right out of the box, either by inserting the battery or clicking it once. The others won’t discover. I went further and added the 3 undiscovered buttons to the Shelly App on my phone, and they seem to function fine there. I’m not sure returning them to Shelly as defective items applies since they work within the Shelly app. How do I open a issue on github for the bluetooth integration. I’d may be willing to mail one of my undiscoverable ones to a developer for debugging purposes.
One try:
Install the Shelly BLE Debug App and check the FW and install a new one. You can also reset it in the app (in my opinion)
And to pair, please press the button for 10 seconds near a gateway
