Hi, the new shelly BLU TRV only supports “heating” as preset. There is no possibility to “turn it off”. I know I can reduce the target temperature to minimum and achieve the same result but it is not convenient to quickly change the status.
The old Shelly WiFi TRV also didn’t support turning it off from the web interface but I guess the integration was doing some magic to simulate it (basically setting it minimal temperature).
Will it be possible to replicate the behaviour for the Shelly BLU TRV?
Thanks.
BLU TRV doesn’t physically support off
mode so also integration doesn’t t support it. If Shelly implements this mode then integration will also support it.
Yes, for old TRV integration supports off
mode but implementing this feature was a mistake and caused more problems than good. That’s why with BLU TRV we stick to the physical capabilities of the device.
I get the point but I don’t like it
Could you please advise where is the best place to open this feature request to shelly?
Probably their support and/or Shelly group on Facebook.
