Shelly Detached Input Blueprint – Switch & Button Mode with Fallback Script (v1.3)
:electric_plug: Shelly Detached Input Blueprint – Switch & Button Mode with Fallback Script (v1.3)
Hi HA Community! :waving_hand:
I’ve released a Home Assistant automation blueprint for Shelly Gen3 & Gen4 devices
configured in detached input mode.
It allows you to use physical switches or buttons to control smart lights or automations
without physically switching mains power, while maintaining predictable behavior
even during Home Assistant restarts.
:brick: Typical use case
Do you want to use a physical wall switch to control your smart lights
without cutting power to the bulbs?
This blueprint is designed exactly for that.
Example setup
  • :light_bulb: Smart lights (Hue, Zigbee, Wi-Fi, etc.)
  • :electric_plug: Shelly Gen3 device in detached mode
  • :radio_button: Classic wall switch or
  • :trackball: Shelly Wall Switch (2)
In this setup:
  • The wall switch does not physically disconnect the lights
  • The Shelly input only reports user interaction
  • Home Assistant handles the smart logic
  • Basic interaction remains functional even if Home Assistant
    is temporarily unavailable, thanks to the local Shelly fallback
This results in a much more reliable and partner-friendly smart lighting experience.
:warning: Safety note
Shelly devices work with mains voltage.
If you are unsure about wiring, consult a qualified professional installer.
:wrench: What does the blueprint support?
:radio_button: Input modes
  • Switch mode
    • Uses a binary_sensor
    • Triggered on OFF ↔ ON transitions
  • Button mode
    • Uses a Shelly event entity
    • Supports:
      • single_push
      • double_push
      • long_push
:light_bulb: Action modes
  • Lamp mode
    • Switch mode → toggle
    • Button mode:
      • single press → toggle
      • double press → 100% brightness
  • Custom mode
    • Define your own actions per event or state
:shield: Optional local fallback (Gen3 & Gen4)
An optional Shelly script provides local confirmation and predictable behavior:
  • Runs directly on the Shelly
  • Generates a short confirmation pulse on every input
  • Continues to work during Home Assistant restarts
  • Same script for switch and button mode
The fallback works together with a virtual confirm switch.
:wrench: Confirm switch configuration
On Shelly Gen3 & Gen4 devices, the confirm switch is a Boolean component.
Steps:
  1. Open the Shelly web interface
  2. Go to Settings → Components
  3. Click Create new → Boolean
  4. Set:
    • Name: confirm
    • View: Toggle
  5. Leave all other options default and save
This component appears in Home Assistant as a switch entity
and can be selected as the Confirm switch in the blueprint.
:warning: Required inputs (HA limitation)
Home Assistant requires all trigger entities to be valid.
This means:
  • Switch mode → switch input is required
  • Button mode → button event entity is required
If an input is not relevant for your selected mode,
simply select any entity — it will be ignored.
:package: Repository
Blueprint, fallback script, and documentation:
:backhand_index_pointing_right: GitHub - willumpie82/homeassistant-blueprints: Homeassistant blueprints · GitHub
:eyes: Sneak peek: v1.4
Planned features:
  • :clapper_board: Scene controller support
  • :light_bulb: Advanced dimming options
  • :trackball: More flexible per-event actions
  • :compass: Further UI improvements
:speech_balloon: Feedback welcome!
Let me know:
  • how you’re using the blueprint
  • which Shelly devices you’re running
  • what you’d like to see in v1.4
Happy automating! :rocket:
:counterclockwise_arrows_button: Update: v1.3 → v1.3.1 (Button Mode Reliability Fix)
I’ve released v1.3.1 of the Shelly Detached Input blueprint.
This is not a feature update, but an important stability and architecture fix.
What changed?
In v1.3, Button mode was based on low-level Shelly event entities.
While functional, this proved to be unreliable across firmware versions and device generations.
From v1.3.1 onward, Button mode is built on native Home Assistant Shelly device triggers.
Why does this matter?
  • :white_check_mark: Consistent behavior on Gen3 & Gen4
  • :white_check_mark: Same trigger mechanism as automations created via the HA UI
  • :white_check_mark: No more “automation triggers but nothing happens”
  • :white_check_mark: Future-proof against Shelly firmware changes
Additional improvements
  • One blueprint per physical button (simpler & more robust)
  • Selectable button number (button1–button4)
  • Optional local fallback using Shelly confirm output
  • Remote debugging support via shelly_button_event
If you’re using v1.3, I strongly recommend upgrading to v1.3.1.
Feedback is always welcome! :waving_hand:
Hey @doubleU just wanted to say thank you for putting in the time and effort to this blueprint.
I found it when using AI to research the most optimal lighting automation - I have been trying to achieve this with automations for years but its never been perfect. I’m still not sure if my use case was one that you built your blueprint for; I have 11 shellies (mix of Gen1,2+3) installed behind traditional rocker switches. About half are directly controlling a dumb light through the shelly output and the other half are detached and use automations to drive zigbee bulbs.
I havent been able to use the blueprint, but my understanding is that I will only want switch mode, as none are momentary switches - is that correct? One very small piece of feedback would be just to make it super clear in the UI and expand to say if you want to use ‘Button’ mode with a physical switch this can only be achieved if you have momentary switches… if I’ve got that right?
Two issues I ran into using your blueprint:
1 - [button mode] has button 1 selected by default and it cannot be unselected, even when having switch as the input mode. HA sees this as a required field no matter what, and the automation wont save.
2 - ‘Confirm switch (optional)’, this field is described as optional but in the form its required, and the automation wont save without an entity in this field.
Because of issue number 1 I cant actually save and test this out (I would love too!), so just wanted to feed that back.
For now I’m still using my simple automations to avoid random turn-ons/offs with connection dropouts:
alias: Guest Room Light Switch
description: >
  Controls the guest room light from a Shelly-connected traditional rocker
  switch. Rocker up turns the light on, rocker down turns it off. Designed to be
  robust against device dropouts and Home Assistant restarts.
triggers:
  - entity_id: binary_sensor.guestroom_lightrelay_ch1
    to: "on"
    trigger: state
    to: "off"
    trigger: state
conditions:
  - condition: template
    value_template: |
      {{ states('light.guestroom_light') in ['on', 'off'] }}
actions:
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - target:
              entity_id: light.guestroom_light
            action: light.turn_on
      - conditions:
        sequence:
          - target:
            action: light.turn_off
mode: single
I love the idea of using scripting on the shellies as redundancy - however (forgive my ignorance) I’m not sure I understand why the scripting is needed, as for me the shellies work fine with dumb bulbs when HA is down.
I guess if there was a way to implement scripting that utilises mqtt when HA is down (my broker sits on a separate pi), and then also controls zigbee bulbs, locally without HA. But appreciate most have ZHA or run Z2m as an add-on…
Thanks again for your efforts!
G
This looks great! I´m looking forward to try it and follow the development.
Thank you!
Thank you for the feedback, I’ll see if I can reproduce the issue and update the BP
The whole BP is build around the Idea of using smart bulbs with the shelly in as button/switch (if you switch off the power of a smart bulb its not considered smart anymore :wink: )
If you use it with dumb bulbs (non-detached mode) I assume some weird toggle behavior
How does this work when Home Assistant is not available?
Does it fallback to attached mode so I can physically toggle the Hue bulb power or how does that work?
Hi, sorry for my verrrrrry late reply,
it kind’a does, when you flip the switch, the scripts makes sure the relay in ‘on’ when you flip the switch again, it waits for the confirm from HA, if that does not arrive in time the relay is switched off, so you will experience a bit of a delay turning off (but for me that is acceptabel since it is the fallback scenario anyway)
