Shelly dimmer 2 flow
I am having trouble creating a flow for my Shelly Dimmer 2. I have a PI3b+ and im using call services through wifi to call my shelly devices. I just havent figure out how to get the dimmer to turn on or how to dim the lights.
This should help
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/cookbook/motion-triggered-light.html#example-1
thank you for your reply but I dont see any examples on how to adjust the dimmer setting. I am able to turn it on and off but I cannot adjust the brightness.
It’d really Strang that I’m the only one who is trying to do this. Is there a better way that others have tried?
Can you expand on this? If you put the brightness data in the call service node it doesn’t change? You should post your flow as well.
ill be honest I have tried all kinds of different ways that I have found online but nothing seems to work. So IF you have suggestion Ill plug it in and see if it works. I dont have anything saved bc nothing seems to work.
