Hey there,
Beginner with home assistant so hopefully someone could help me.
I have lots of shelly 1’s allready integrated through mqtt (as shelly integration is lagging up to a minute (poll??)
All shelly 1’s are working fine
Now I have a Shelly dimmer 2 but however I can see it when I announce a message in configuration I can’t get it to switch on/off the device.
It must be something easy in the configuration but I can’t figure it out… have tried several configs found on google but o luck till now.
This is the json output on aanounce message
Bericht 94 ontvangen op shellies/shellydimmer2-98CDAC0D46BA/info om 15:26:
"wifi_sta": {
"connected": true,
"ssid": "KnipIOT",
"ip": "192.168.40.171",
"rssi": -41
"cloud": {
"enabled": false,
"connected": false
"mqtt": {
"connected": true
"time": "15:26",
"unixtime": 1684762012,
"serial": 1,
"has_update": false,
"mac": "98CDAC0D46BA",
"cfg_changed_cnt": 0,
"actions_stats": {
"skipped": 0
"lights": [
"ison": false,
"source": "http",
"has_timer": false,
"timer_started": 0,
"timer_duration": 0,
"timer_remaining": 0,
"mode": "white",
"brightness": 100,
"transition": 0
"meters": [
"power": 0,
"overpower": 0,
"is_valid": true,
"timestamp": 1684769212,
"counters": [
0,
0,
0
"total": 27
"inputs": [
"input": 0,
"event": "",
"event_cnt": 0
"input": 0,
"event": "",
"event_cnt": 0
"tmp": {
"tC": 35.94,
"tF": 96.69,
"is_valid": true
"calibrated": false,
"calib_progress": 0,
"calib_status": 0,
"calib_running": 0,
"wire_mode": 1,
"forced_neutral": false,
"overtemperature": false,
"loaderror": 0,
"overpower": false,
"debug": 0,
"update": {
"status": "idle",
"new_version": "20230510-082920/v1.13.1-gda6f9f2",
"old_version": "20230510-082920/v1.13.1-gda6f9f2"
"ram_total": 49672,
"ram_free": 36964,
"fs_size": 233681,
"fs_free": 118974,
"uptime": 6139
This is (part of) my mqtt.yaml
First spotszolder which is working fine second dimmer2
- name: shelly1pm-spotszolder
unique_id: shelly1pm-spotszolder
# 192.168.40.170 Spots Zolder
payload_on: "on"
payload_off: "off"
qos: 0
state_topic: shellies/shelly1-349454720177/relay/0
command_topic: shellies/shelly1-349454720177/relay/0/command
json_attributes_topic: shellies/shelly1-349454720177/info
optimistic: false
- name: shellydimmer2-lampzolder
unique_id: shellydimmer2-lampzolder
# 192.168.40.171 Lamp Zolder
payload_on: "on"
payload_off: "off"
#brightness_scale: 100
qos: 0
state_topic: shellies/shellydimmer2-98CDAC0D46BA/relay/0
command_topic: shellies/shellydimmer2-98CDAC0D46BA/relay/0/command
json_attributes_topic: shellies/shellydimmer2-98CDAC0D46BA/info
optimistic: false
Any help into the right direction would be apreciated
