Shelly Dimmer or Sonoff D1 Dimmer
I’m looking for a dimmer switch to control 4 low wattage LED lights. It will be located in the ceiling and I won’t have a physical switch, only use automations. Neutral wire is present.
The two options I have found are the Shelly Dimmer and the Sonoff D1 Dimmer. Both fairly new products.
Does anyone have experience with both products or can recommend one or the other for my use case?
