Shelly dimmer2 configure error
Hi everyone,
I just purchased a heap of shelly dimmer2s for my house. I have one connected up and connected it to my 2.4ghz network. I can see it fine and renamed it to masterBedroom.
Home assistant can see it it came up in discovered, i pressed configure, the only options I get is IP and port. I am assuming the port is 80.
I have read through the Shelly guide a few times, though I’m unsure what generation this dimmer2 is.
basically is am getting this error:
Needs Attention:
masterBedroom
No devices or entities
Failed setup, will retry: None
Devices
No entries
I don’t know if its meant to be a device or and entity, and I cant see any other way to change anything but the IP or the port.
okay clicking to the device in HA I was able to click enable debugging, and I got a notification says the firmware was too old. updated and the Shelly hooked up right away. So port must be 80
