I have a shelly em device that gives me watts,voltage and power factor sensors in HA,is it possible to create a template sensor to give me the option of having an amps sensor as well.I would appreciate any help in setting this up via template sensor helper or yaml.Example to copy and paste would be welcome.
Yes the weather is fine!
It would be more effective if you posted a question.
If you are asking if you get a sensor when you integrate it in HA, the answer is yes, it does that itself.
