Shelly Gen 4 + Addon + Zigbee
If you have come to this post seeking answers on rather if the addon data will be pushed over zigbee with a shelly gen 4 device I can confirm it does not. This is quite possibly the same for Matter as well but that I cannot confirm.
I feel Shelly has missed a great opportunity in providing smart home users something that no other company provides, at least bundled in a single device. According to a Reddit post Shelly has no future plans to add this capability to the Shelly Gen 4 devices either but the light at the end of the tunnel hasn’t gone out completely yet.
I have made this post to not only answer an important question I had prior to purchasing these devices and could not easily find an answer too but also to implore those of you who like Shelly products such as myself and would like to see more use come out of existing devices than what’s already provided.
If you are unfamiliar with the Shelly Addon it was originally a snap on extension that broke out 3 wires (VCC, DATA, GND) and provided a means of attaching various sensors such as DS18B20 for temperature or a DHT22 for Temp/Humid among other sensors. It was limited on what you could attach but was still a nice addition. I still have a Shelly 1 Gen 1 with addon in service today controlling a garage door along with two reed switches. The new Shelly Addon Plus provides even more capabilities with an additional Digital and Analog support.
Now I realize these devices can be made DIY and for cheaper but many of us still prefer to purchase something that doesn’t require a soldering iron and nearly everything you can connect to the Addon is already available as an end device for Zigbee (except the battery powered zigbee voltage meter which the Shelly 1 Gen 4 w/Addon could do). The ability to have a single Zigbee device push multiple various data as well act as a router would be awesome. I have currently replaced one of the two Shelly 1 Gen 1 w/Addon with a Shelly 1 Gen 4 w/Addon and added a DHT22 as well as two contact sensors and it works perfectly over wifi but would much rather be able to switch it over to Zigbee.
If you would like to maybe see Shelly Gen 4 devices with the Shelly Addon Plus push the Addon data over Zigbee (and possibly Matter) Please take a moment to submit a feature request,
Shelly Feature Request
Here is a video I had found highlighting some of the possibilities the Shelly Addon Plus can do.
Well, it’s nice to see that I’m not the only one in this situation. I have a Shelly 1 Gen 4 with the latest FW (1.7) and switched to Zigbee mode. I added the Shelly Addon Plus Sensor, but unfortunately, in Zigbee mode, it doesn’t display the information from the add-on, only that from the 1 Gen 4. I wrote to support and am waiting for a response from them.
I was searching for info about the ability to read addon via zigbee and i found this thread. So i think you saved me from experimenting by myself.
But indeed it would be a nice feature to have :frowning:
Only being able to control the dry contact through Zigbee is a nice feat, it’s really nice to not be dependent on WiFi anymore. But I agree it would have been a lot more useful to have the other states exposed to Zigbee as well.
I’ve made a thread about the SW state on their community forums, let’s hope they respond positively to it.
Lots of people have already requested Shelly to expose the switch inputs in zigbee mode, so they’re fully aware.
There’s a thread on Reddit where someone was told by Shelly that this will be part of firmware 1.8, whenever that’s released
Great news, as I wanted to replace a Gen1 of the 1PM that I am using with the AddOn to read temperature and humidity.
I did not even consider that Zigbee-mode would not convey the AddOn data.
Hypothetically I could leave the WiFi mode enabled and connect the device both via Zigbee and WiFi, but as the latter is not reliable in the device’s area and the reason to join the 1PM to the Zigbee mesh network for stability.
