You can just use the normal 1.7.1 firmware. There is a “Switch to Zigbee” function now in the Settings > Device settings menu now. WiFi can stay enabled and used alongside Zigbee, Bluetooth must be disabled.
Mine works with Bluetooth enabled.
Just an update - my Shelly 1 gen 4 switched over to Zigbee via web interface successfully with Bluetooth off as per comments above. ZHA found it fine and the relay works via zha but still no support for peripherals. Ie. temp and hum show up on the Shelly app but don’t pull through to HA via ZHA. Any chance that a custom quirk can expose the temp and hum? I’m not skilled enough in that area to make that work.
I just stumbled over this thread and maybe somebody has an idea.
I have to 1PM Gen4 Mini devices with firmware 1.7.1 connected with Zigbee and ZHA. Bluetooth and unluckily Wifi is disabled.
One of them reports zero voltage values exactly every 5 minutes for a few seconds. Sometimes it just ignores switching the wall switch or seconds later after turning it off the switch turns the lamp back on. I need to verify but I have the feeling it happens if I trigger something in this 5 seconds 0 voltage time windows. Anybody has an idea? The other shelly seems fine.
Is there a way to access/enable the Wifi AP over Zigbee?
Edit: I opened the wallbox and enabled the AP. Turns out bluetooth was still activated. I disabled it and enabled Zigbee again. But bluetooth is back alive and the issue persists. Also the AP was disabled. Maybe a hardware issue…
Do Wifi and Zigbee really work simultanously?
Yep i have one doing exactly that, connected to HA via zigbee but i can still access it’s webserver via it’s IP address.
