I have integrated some Shelly Dimmers in home assistant behind some normal switch buttons. Now i want to use the press of these button in an automation to nog only toggle the light directly connected to the Shelly dimmer but also another light.
When i press the button i see Long Click event that turns on the light directly connected to the Shelly Dimmer. My automation also picks up this event an toggles another light. So this works well!
When i turn of the light by pressing the switch down the light directly connected to the Shelly Dimmer is turned off but no event is triggered. So i`m unable to let the automation turn off the other light.
See screenshot for the events.
Why isn`t there an event when i turn the switch off? Is this possible to realise?
