Hello everyone, I implemented in HA using ESPhome and an esp8266 Node MCU board, a binary sensor capable of providing the status of the home alarm system, otherwise completely separate from HA.
The aim was to create an automation that used the status of this sensor “binary_sensor.stato alarm” to prevent, with the alarm armed, the movement of the shutters (cover), mounted on the outside of the windows, on which are installed protection devices capable of triggering the alarm.
I specify that each shutter is controlled with “Shelly Plus 2PM”.
However, I was unable to find a way to solve the problem. I found indications regarding the use of a “shelly.lock” service, but it does not seem to exist.
Is it possible to imagine that this functionality can be activated in the near future?
Is there anyone among you who has faced and solved this question?
I attach the code that returns the alarm status:
esphome:
friendly_name: stato-allarme
platform: ESP8266
board: d1_mini
logger:
api:
encryption:
key: "##########################################"
ota:
password: "####################################"
wifi:
ssid: !secret wifi_ssid
fast_connect: true
manual_ip:
static_ip: 192.168.yyy.xxx
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Stato-Allarme Fallback Hotspot"
password: "òòòòòòòòòòòòòòòòòòò"
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: D1
inverted: true
mode:
input: true
pullup: true
device_class: safety
